Preprocessing
Preprocessing
To achieve node merging in ANSYS mesh tool
    • Supreethm
      Here is the normal setup that needs to be meshed. It consists of a disc inside a plate with a hole. Both have thickness of 4mm. When I try to mesh the parts the nodes see
    • Supreethm
      After meshing the nodes are not merged.
    • Supreethm
      A closer look into the region
      Developing some refined meshing techniques
    • Supreethm
      Refined meshRefined mesh
      Refined the mesh to achieve more number of elements.
    • Supreethm
      Even after the refined mesh still unable to achieve the node merging criteria.
    • peteroznewman
      In Workbench, right mouse click on the Geometry tab and Edit in DesignModeler.
      In DesignModeler, you will see two solids listed at the bottom of the outline window on the left.
      Select both solids and right mouse click to Form New Part.  This has enabled Shared Topology.
      Close DesignModeler
      Open the Model or Mesh depending on which analysis system you are using.
      Generate Mesh and you should see shared nodes on the boundary.
Viewing 5 reply threads
