Tolology Optimization error?!
    • Heiko Theiss
      I am trying to do a topology optimization. My static-structual data should be ok, but when I start the optimization it doesn´t advance at some point.
      The status bar just says: "optimization is being prepared:Constant data is read" (Translated).
      And if I try to stop the simulation, the program is beeing frozen.
      Does anyone know how to solve this problem? Thanks in advance
    • Ashish Khemka
      Hi Heiko,
      Do you see any errors? Can you please check for the error file, if present? Following post may help you to look for error file:
      Unknown Error- “The optimization run was terminated check the optimization output … (ansys.com)
      Ashish Khemka
    • Heiko Theiss
      Thanks for the quick reply.
      Sadly the is no error nor warning. It sems to work, but in reality it does not advance. I think its an error, just because I have to force close the application when I use the stop command.
