Top-free surface boundary condition
    • cs437
      I read papers about free surface; however, I found two types of boundary conditions should be set are pressure-outlet boundary condition and wall with zero shear stress. I tried both cases in the simulation. As far as I have done, the torque values are similar; however, the reducing of the iterations are different. Could anyone tell me which is more appropriate boundary condition if the problem is about free surface on the top of a geometry?
      Best regards,
    • DrAmine
      Free slip wall is a simplification of applied direct at free surface. Ideally one would have a buffer above the free surface and pressure boundary at the top. If one enlarges domain
    • DrAmine
      Then one can apply a symmetry or free slip wall.
    • cs437
      Sorry, could you clarify "one"  and its explanation?
      Thank you.
    • DrAmine
      It you put enough place above the free surface one can think abiut using symmetry bc.
Viewing 4 reply threads
