Discovery Import
Discovery Import
Topological Optimization (opt parts) – Discovery Live 2019 R3
    • s251854
        It is possible to get optimization of parts as parts and not as a system. The idea is that they work together, but to get separate parts and not one. Because in did the parts are not bonded. The only connection between the parts is a small lip attached to the side parts. The one from the middle supported by this two lips. Thanks
    • Naresh Patre
      Hello Agustin
      Currently, all contacts are modeled as bonded in Discovery Live. So the optimized result will be based on the effects of bonded contacts at all locations in the model.
      If you can provide detailed information about the loads and boundary conditions for this model, I can check if the parts can be optimized separately.
      • s251854
        Naresh Patre should be a good thing to have a contact option like other softwares. This tool is amazing, good results and really fast :)
      • Naresh Patre
        Hello Agustin
        You might want to vote for the below mentioned idea:
        https://discoveryforum.ansys.com/t/k9wcpq/non-bonded-contacts
      • s251854
        Naresh Patre great. 6 votes, 1 year.... I hope at least to think about it :)
