Topology optimization help!
    • hakan
      hello everyone,
      i'm beginner on topology optimization and i encountered an error like "Topology Optimization does not support a Static Structural solution selection with inertial, FSI and voltage based loads."
      you can find the below pictures about my issue. how can i fix it? i'm using ansys 18.0
    • Mike Rife
      Hi hakan
      Use a later version - 18.0 is quite old at this point.
    • hakan
      thank you mike. but i must use this version a while. however,  i can't understand the issue. what does it mean? and i need the solution immediately. thanks again.
    • Mike Rife
      Hi hakan
      Look at the error message - it states that inertial loads in the structural are not supported for the TO solve.  And the structural model has gravity...
Viewing 3 reply threads
