Discovery Import
Discovery Import
Topology Optimization with multiple Load Cases
    • hilmar.meienberg
      Actually I have 2020R2.5.1 installed but the "Include Simulations" selection doesn't appear although I have defined multiple simulations. Is there a trick to activate this feature or what do I have to do? The screenshot is from an ANSYS webinar.
    • hilmar.meienberg
      Strangely enough, this does not work with the existing "Bracket Optimization" example. If you create a completely new model in Discovery, this selection appears and several load cases can be combined.
      Sorry for the confusion.
    • hilmar.meienberg
      This is weird. Please try to combine the two simulations in the attached model for a topology optimization. I can't figure it out.
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Charudatta Bandgar
      Hello Healme ,
      Combining multiple loadcases is not yet possible in the current version of the Discovery, but it will be added in the next version 2021R1. Sorry for the inconvenience.
      Regards.
      • hilmar.meienberg
        Charudatta Bandgar , I checked this feature in 2021R1 and it is still unavailable . Will it come with 2021R2 then?
        Apologies for that,Healme
        I will confirm and let you know.
        Regards.
Viewing 3 reply threads
