April 24, 2023 at 11:32 am
sampathkumar
SubscriberI am designing hub motor with 36 slot 4 pole 1kw.I am not getting the torque.The average value is zero.are there any slot pole combinations for which torque is obtained?
April 25, 2023 at 12:14 pm
Navya C
Ansys EmployeeHi sampathkumar,
You can check if the winding excitations and motion setup are properly assigned to make sure there is no error in the simulation setup.
Ansys employees cannot provide design suggestions on the forum. We encourage other participants in the forum to pitch in if there is any design suggestion in this.Regards,
Navya
- Maxwell, HFSS or Q3D?
- Error
5268
3299
2469
