Torque Characterstics of a 3 Phase Induction Motor
    • Dushyant
      I am running transient simulation on a 3 Phase Induction Motor in Maxwell 2D but for some reason the torque vs time graph is oscillating around 0 or going negative. And the torque vs. speed curve is coming to be a straight line.
    • fardeenzaidi
      I am Facing exactly similar problem. n
    • Navya C
      Hi,nCan you provide more information on nwhat is the approach you followed for creating your 2D model? - Created 2D model from RMxprt or imported a 2D geometry and set up the model directly in Maxwell 2D.nWhat is you motion setup and excitation settingsnWhich version of Maxwell are you using?nAny additional details in understanding your setup will be helpful.nnRegardsnNavyan
    • Dushyant
      Hi,nI Designed the motor First in RMxeprt. It is a 4 pole, 72V motor. I tried to changing the winding properties but still the power factor is coming to be too low, which is affecting the torque.n
Viewing 3 reply threads
