October 19, 2018 at 8:42 am
motoyama
SubscriberHi everyone,
I simulate two blade wind turbine with MRF.
but as rotational speed 'omega' increase, torque also increase.
so there is no peak on power coefficient.
How can I calculate it?
October 19, 2018 at 9:10 am
Keyur Kanade
Ansys EmployeeHi,
How are you calculating torque?
October 19, 2018 at 9:12 am
Keyur Kanade
Ansys EmployeeHi
How are you calculating torque? Please give more details. Please insert some images and explain the problem.
In general, you can do following to calculate torque.
Please follow the steps below:
Keyur
October 19, 2018 at 9:14 am
Keyur Kanade
Ansys EmployeeSorry post is giving some error to me.
1) Click “Report → Force” to open the Force Reports panel -
Keyur Kanade
Ansys Employee2) In “Options”, select “Moments”
October 19, 2018 at 9:15 am
Keyur Kanade
Ansys Employee3) Enter the coordinates of the center point of the rotation for “Moment Center” and the axis at “Moment
Axis” -
Keyur Kanade
Ansys Employee4) Select the Wall Zones
Keyur Kanade
Ansys Employeethat will serve as the plane of rotation from where the torque will be calculated
5) “Print” will show the results in the Console Window
October 19, 2018 at 9:16 am
Keyur Kanade
Ansys EmployeeI am really sorry, I am getting some errors while posting it. May be some maintenance work is going on.
Hope you can read these posts.
Keyur
October 19, 2018 at 9:30 am
October 19, 2018 at 9:37 am
DrAmine
Ansys EmployeeYour torque is constant from the plot. Can you please add some more information here? If there is a linear momentum then the torque will change even at constant angular velocity.
October 19, 2018 at 9:50 am
October 19, 2018 at 9:57 am
Ansys EmployeeOK, why should torque be the same for different speeds? Ie, what is the definition?
October 19, 2018 at 10:05 am
motoyama
SubscriberHi , rwoolhou
the torque value means half of the moment that i calculate
well, I think torque is not same as for different speeds.
from the tip speed ratio, there should be a Cp peak.
October 19, 2018 at 10:32 am
October 19, 2018 at 10:37 am
Ansys EmployeeI'm not sure I understand. If you expect the torque to change with speed, what is the problem?
October 19, 2018 at 10:44 am
motoyama
Subscriberthe problem is that torque increase and decrease as the rotational speed increase.
so Cp=torque x omega should have peak.
but this data shows torque only increases but not decrease.
October 19, 2018 at 10:59 am
DrAmine
Ansys EmployeeFrom the data you are mentioning I do only detect single trend: torque is increasing as the angular velocity is increasing (due to linear mometum). So now: What is the problem?
October 19, 2018 at 11:53 am
motoyama
SubscriberHi Amine
I searched the similar examples
please refer below
https://www.cfd-online.com/Forums/cfx/160097-problem-torque-calculation.html
October 19, 2018 at 12:22 pm
Ansys EmployeeThat's not the problem, you need to define & explain why you think your answer is wrong. As you've read through the whole of that thread, have you also found the same problem with a finer & much finer mesh?
Note, as ANSYS staff we can't download and/or open project files.
2524
2066
1279
1096
457
