TORSIONAL AND LATERAL ANALYSIS BY USING 3D MODELS CONNECTING WITH MOTOR SHAFT
    • PRASANNA KRISHNA KOPPISETTI
      Hai,
      I am facing an issue to do analysis on rotor shaft which was connected to a motor shaft,
      bearing and impeller laods acting, two shafts connected with a coupling.
      by 3D models can you plese help
    • Sahil Sura
      Hi PRASANNA KRISHNA KOPPISETTI,
      Would you please share some details of the model?
      Images you find relevant in explaining can be attached using the 'insert image' tool.
      You can get more insights on how to set up connections from the following course- Connecting Parts Together - ANSYS Innovation Courses
      Hope this helps.
      Thanks,
      Sahil
