Torsional Stiffness and Damping for Cylindrical double roller and Taper double roller bearings
    • dvinoth1989
      I am doing a dynamic analysis of a grinding equipment using Ansys Workbench - Transient analysis. The equipment consist of Cylindrical double roller bearing and Taper double roller bearing. Bearing is not designed in detail, instead we have provided the Revolute joints. What is the role of Torsional stiffness and damping in the bearing joint and how to calculate the values.
      Thanks.
      Vinoth D
      M.S - Aerospace Engineering
      Indian Institute of Technology Madras.
    • rbinc1989
      Hi dvinoth1989,
      I did some research on this and what i've found this:
      http://www.mm.bme.hu/~gyebro/files/ans_help_v182/ans_cmd/Hlp_C_TB.html
      Add commandline inside of ANSYS mechanical.
      (TB) use this command with extras to add rotational stiffness to the specific element.
      JNS is for stiffness and JND for damping.
      Hope it helped and i understood your question.
      Best regards
    • dvinoth1989
      Hi rbinc1989,
      Thanks for your reply. I would like to know, how to calculate the torsional stiffness and damping in bearing.
      I want either the literature study or the Ansys procedure to calculate the stiffness and damping of Taper and Cylindrical double roller bearings.
      Thanks in advance.
      Vinoth D
    • Wenlong
Viewing 3 reply threads
