total heat transfer rate and total sensible heat transfer rate
    • Weiqiang Liu
      Hi all,
      I am modeling a combustion flow with fluent. All the residuals are flat and below some critical values and monitored variables are constant as well.
      I tried to check the flux balance of the whole system. I seclected whole boundaries in the model. The mass flow rate is balanced. However, the total heat transfer rate is -26.81818W and the total sensible heat transfer rate is -2.025117W.  I know that sensible heat transfer rate does not account for chemical reaction heat.  However, I just reported net results, which means chemical reaction heat is included. Therefore, these two values should be the same and they should be both very close to 0.
      I am wondering why they are different? How can I make these values close to 0 when modeling complicated combustion flow?
      Best regards
      Weiqiang
Viewing 0 reply threads
