March 16, 2022 at 10:22 am
sagar
SubscriberHow to find the total runtime of the different modules in Lumerical? Is it possible to generate a report through software?
March 16, 2022 at 5:28 pmLito Yap
Ansys EmployeeThe simulation runtime will depend on the simulation itself and the machine running the simulation. This would vary per simulation per machine. After running the simulation, the "simulation_p0.log" file will contain the simulation job/run information. You can get the optimum resource configuration for FDTD for your machine as shown in this post.
- Error on Lumerical device
2666
2120
1349
1132
461
