August 9, 2019 at 8:56 am
KeWu
SubscriberHi there,
I am facing a problem with probing the state of a beam. I am trying to figure out if it is under tensile force or compressing force in the direction of its axial and the value of the force.
BTW, both ends of the beam are connected to other solid parts in Fixed Joint.
Thank you in advance,
Ke
August 9, 2019 at 10:19 am
jj77
SubscriberIf you post an image on your model and the areas you are mentioning and what type of stress you look at then we can help. Is it a beam element solid,...
August 9, 2019 at 12:18 pm
SubscriberIf it is a Beam element, you can insert the Beam Tool into the results and the Direct Stress is the axial stress. Tension is positive compression is negative stress.
August 13, 2019 at 9:14 am
KeWu
SubscriberThank you for your reply!
I've fixed it.
Ke
KeWu
I've fixed it.
Ke
2088
1321
1108
459
