Tracer amount keeps on increasing in the tundish during RTD calcuation for two phase flow
    • Abhinav_Maurya
      Steps being followed:
      (Before tracer injection)
      1. Setup: realizable K-e, standard wall functions; Multiphase - VOF; Species transport: OFF
      2. Side Inlet: Air (Vol. frac 0); Top Inlet: Water (Vol. frac 1)
      Ran the simulation in steady state, obtained converged solution post 20000 iterations.
      (During tracer injection) - Switched to Transient simulation
      2. Side Inlet: Air (Vol. frac 0); Top Inlet: Water (Vol. frac 1 but tracer mass fraction = 1)
      3. In the solution --> Controls --> Equation, Flow: Off, Volume Fraction: On, Turbulence: On, Tracer: On
      (Post Tracer Injection)
      [Method 1]
      2. Side Inlet: Air (Vol. frac 0); Top Inlet: Water (Vol. frac 1 but tracer mass fraction = 0)
      3. In the solution --> Controls --> Equation, Flow: On, Volume Fraction: On, Turbulence: On, Tracer: Off
      [Method 2]
      3. In the solution --> Controls --> Equation, Flow: On, Volume Fraction: On, Turbulence: On, Tracer: On
      While following Method 1, tracer amount doesn't increase in tundish. However, if method 2 is followed, tracer amount increases.
      P.S: When the simulation was performed using method 2 for the homogeneous phase, the simulation ran smoothly
      How are you adding a tracer if species is off?
    • Abhinav_Maurya
      Correction: Species transport is on During tracer injection and Post tracer injection
      What's the difference between Method 1 & 2?
Viewing 4 reply threads
