Photonics
Photonics
transmittance script for circularly polarized light
    • ejlee0911
      Hello.
      I have a question about calculating the transmittance of circularly polarized light.
      I use the LCP for source with Fabry Perot cavity optimized for circularly polarized light.
      The Fabry Perot cavity I use may show different results for LCP and RCP.
      So I have to check the transmittance and reflectance of each circular polarization.
      To find out the optical properties, I use the script below referring to https://forum.ansys.com/forums/topic/YuanPianZhenGuangQiuZhuanHuanXiaoLu/.
      I want to know if the script is right.
      # Total energy of LCP component of monitors (R and T)
      f=getdata("R","f");
      lamda=c/f;
      x=getdata("R","x");
      y=getdata("R","y");
      R_Ex=getdata("R","Ex");
      R_Ey=getdata("R","Ey");
      R_T=getresult("R","T");
      Ex0 = pinch(R_Ex(find(x,0),find(y,0),1,:));
      Ey0 = pinch(R_Ey(find(x,0),find(y,0),1,:));
      R_data = R_T.T;
      RCP_R2 = (Ex0+1i*Ey0)/sqrt(2);
      LCP_R2 = (Ex0-1i*Ey0)/sqrt(2);
      prop_RCP_R2 = abs(RCP_R2)^2;# total energy of RCP component of T
      prop_LCP_R2 = abs(LCP_R2)^2;# total energy of LCP component of T
      R_R = R_data*prop_RT_R2;
      R_L = R_data*prop_LT_R2;
      plot(c/f,prop_RT_R2, prop_LT_R2, "lambda","Re_RCP", "Re_LCP");
      RCP_R2 is the EM equation. I guess, "prop RCP_R2" is the power of the reflectance of RCP.
      The definition of reflectance and transmittance is power/power, so is it need for 'prop RCP_R2' to divide by the total power of the source to figure out the reflectance or transmittance?
      In the reference post, the writer used the script function 'TotalEnergy' in the second picture.
    • Greg Baethge
      Hi ejlee0911,
      Thank you for posting your question on our forum. I think the overall idea of reconstructing the LCP and RCP response is going in the right direction, but the script only takes the E field components at the center of the monitor. I think a more generic approach is possible using S parameter calculations, as discussed here.
      The idea is similar, we calculate the s and p components of the S parameters, and reconstruct the LCP and RCP to get the conversion efficiency.
      I hope this will help.
    • ejlee0911
      Thanks for your help!
      I have a question to use S parameter.
      A generic approach you kindly mentioned is applied for metasurfaces in which the incident light was coming outside from them.
      But I would like to check the results when the source is inside the structure. And is it still okay to define the metamaterial span and center?
