Transfer load
    • mekafime
      Hello,nHow can I create a volume to which I will apply a load and this can be transferred to the structure (that supports this volume) this volume should not participate in the design?n
    • Govindan Nagappan
      @mekafime nIn the details of the volume, set the stiffness behavior to rigid. This way, the solid is represented by a mass element and is not meshed. Only the contact faces are meshed to transfer the loadnn n
