Transfer temperatures during solve from thermal into mechanical
    • Jan123
      In a transient thermal simulation i set temperatures by the D-command to certain regions and delete the fixation again at later timesteps by DDELE. I use SOLID90s and created SURF152 Elements where needed in a custom command preprocessing step. I get nice results for the thermal simulation, so far so good.
      But if i then import the resulting body temperature as a load for a mechanical simulation, the DDELE seems not to be considered, nor the cooling from convection.
      I tried selecting all nodes, not the body, in the imported body temperature - it makes no difference.
      How can i transfer the temp-solution i see in post processing into mechanical?
Viewing 0 reply threads
