September 21, 2018 at 10:27 pm
jonsys
SubscriberLet's call x a value/parameter that I calculate in "Design Modeler > Parameter Editor tab". I want this value (or 2x or 1/2x or whatever) to use it as the input of displacement in Mechanical.
Now the part where it gets complicated is that displacement will be applied in steps, meaning there is a tabular data for displacement input. However, these data will still be dependent on that x value.
September 22, 2018 at 3:00 am
SubscriberJon,
The Parameter doesn't come from DesignModeler, it is created directly in the Parameter Set in Mechanical.
Below you can see one parameter DS_disp that came from DesignModeler, but that is only for changing geometry.
When you create a Displacement BC and click the P button next to the value you type, it shows up in the Parameter Set.
It's not possible to have a multistep solution with Parameter inputs. I have hit that question myself.
September 26, 2018 at 4:18 pm
Rohith Patchigolla
Ansys EmployeeHi Jon,
As Peter said, it is not possible natively to have a multistep load as a parameter.
But, you can use an App (ACT extension) called "MultiStep Parametric Loads" from the Ansys App store at the below link.
https://catalog.ansys.com/product/5b3bc6857a2f9a5c90d32e84/multistep-parametr
This can support parametrization of loads such as Force, Pressure, Moment, and Displacement.
I tested this in v19.2 and it works well. Below is a snapshot of parametrization of Y displacement in a two step simulation.
Ofcourse, we can always use APDL commands to parametrize the loads in a multistep analysis, by defining the loads via APDL commands instead of GUI.
Best regards,
Rohith
October 8, 2018 at 6:49 pm
jonsys
Subscriberthank you Rohith,
that app was really helpful; I didn't know such things existed.
As I can see, this app is not created from ANSYS. How "safe" is to use these apps?
October 25, 2018 at 9:01 am
Rohith Patchigolla
Ansys EmployeeJon,
In general, they are safe, but, I would say, use it with caution and validate it first.
Best regards,
Rohith
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
