April 25, 2023 at 12:52 pm
May 3, 2023 at 7:06 am
GLUO
Ansys EmployeeHi,
The transfered power depends on the load condition of the receiver. If the receiver is just a closed loop coil without load, the transfered power is the solid loss on the receiver.
GL
May 4, 2023 at 1:37 am
waqas99
Subscriber@GLUO
Thanks for the reply. I have a some supplementary questions.
1. How do I attach a load in the Ansys Electronic Desktop? I am using v19 at the moment.
2. If I cant attach a load, then is there any other solution from which I can calculate the tranfered power and hence the efficiency?Best,
Waqas
- Maxwell, HFSS or Q3D?
- Error
5454
3419
2473
1310
1022
