June 21, 2022 at 9:58 am
PawelTrybus
SubscriberIn random vibration analysis, Is it possible to get results i.e. directional acceleration in coordinate system other than solution coordinate system? Option to change coordinate system is inactive for random vibration.
June 28, 2022 at 7:08 pm
Daniel Shaw
Ansys EmployeeNo. Random Vibration results cannot be transformed into a local coordinate system because the component results are unsigned. The only valid results system is the solution coordinate system.
July 4, 2022 at 11:48 am
PawelTrybus
SubscriberDaniel thank you for the answer. Although, can you explain more thoroughly? My understanding would be that if we have a vector, because we talk about coordinate systems, we can transform it into some other coordinate system. Isn't it similar to deriving von Mises stress from the random vibrations analysis? I would appreciate if you could help more! Thank you :)
3842
2607
1853
1244
600
