March 16, 2022 at 6:16 am
Guillaume ANFOSSI
Subscriberš This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
I have a part positioning problem when creating geometry with scripting in the context of assembly.
If I create the geometry directly at the root, it's ok.
But if the solid is created in the component, I get a positionning offset.Should i useĀ TransformToMaster command ? How it works ?
Thanks,
March 16, 2022 at 6:57 am
Devendra Badgujar
Ansys EmployeeHiĀ GUICAD
Let me check and get back to you.
March 16, 2022 at 1:54 pm
Devendra Badgujar
Here is what you need to add at the end.
transform body
Python
newBody=DesignBody.Create(mypart,"circle",mycircle) mycomp=GetRootPart().Components[1] mycompFrame=mycomp.GetAllCoordinateSystems()[0].FramemycompMatrix=Matrix.CreateMapping(mycompFrame) newBody.Transform(mycompMatrix.Inverse)
It looks at the component the new body is going into to get the local coordinate system, then it creates a matrix mapping and uses the inverse to transform the body.
Please let me know if you need any further assistance on this.
Regards.
March 17, 2022 at 9:38 am
Guillaume ANFOSSI
SubscriberGreat ! Thanks
Computational Fluid Dynamics (CFD) helps engineers design products in which the flow of fluid components is a significant challenge. These different use cases often require large complex models to solve on a traditional workstation. Click here to join this event to learn how to leverage Ansys Fluids on the cloud, thanks to Ansys Gateway powered by AWS.Ā
Earth Rescue ā An Ansys Online Series
3862
2629
1859
1252
600
Ā© 2023 Copyright ANSYS, Inc. All rights reserved.
