June 15, 2022 at 8:06 am
benoitbattail
SubscriberHello,
I am trying to complete a transiant simulation of an LLC converter using Maxwell.
However, it's like I have no magnetic link between prim and sec of my transformer.
So, the voltage source at the input of the converters is creating some watheforms, but at sec side, as the load is only a resistance, there is no voltage.
Did someone already faced this issue ? I could send you some watheforms but I need to relaunch the simulation.
Thank you so much, regards,
Benoit Battail -
June 20, 2022 at 3:33 pm
Dan Dvorscak
Ansys EmployeeI don't see a mutual inductance component in that schematic. If you have not added and set up one of those, then you would not see any induced votlage on secondary side.
November 21, 2022 at 10:58 am
benoitbattail
SubscriberViewing 2 reply threads
July 1, 2022 at 11:02 am
Navya C
Ansys EmployeeHi @benoitbattail,
Geometrically, are both the coils sharing the same core?
Please share some screenshots of the model to understand the design.
Navya
November 21, 2022 at 10:57 am
benoitbattail
- Maxwell, HFSS or Q3D?
- Error
3930
2649
1863
1272
610
