August 15, 2018 at 12:24 pm
Sebastian
SubscriberDear ANSYS Community,
I want to simulate a Transient 3D Co-Simulation between ANSYS Simplorer and Maxwell 3D. So I created a Co-Simulation in Simlprer and set up the Current Excitations and a Motion Setup. In 2d that works fine! In 3D I got the following message in Simplorer :"Simulation completed withe execution error on server.Local Machine / An external simulator couldn't be setup for simulation". When I have a look on Maxwell the following message: " Command line parameters are not valid / Simulation completed with execution error on server. Local machine"
Unfortunately the file is to big to attach it in the community.
Does anyboy have an idea what could be the problem?
Thanks a lot in advance
Sebastian
August 15, 2018 at 4:32 pm
DrAmine
Ansys EmployeeMoving this topic in the related thread
September 13, 2018 at 11:07 am
sidharthpunia10500
SubscriberHi
I am also struck with a similar problem.
Currently, I am trying to integrate Maxwell 3D design with circuits in Simplorer. I want to sweep some physical parameters (location) in Maxwell model, and derive power from Simplorer. Running with fixed parameters works, sweeping within Maxwell also works, but when sweeping integrated maxwell parameters in the Simplorer, it says "error on set parameter". Do you have any idea about what is happening and what is the correct way to do the sweep?
Attached are some related screenshots.
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
457
