March 16, 2021 at 10:32 am
ChaitanyaDS
SubscriberI am simulating a linear induction motor and I have tried a few excitation configurations by changing the winding configuration. Every time I simulate a certain period of time for capturing the motion, it gives a linear position vs time curve. It does not make sense that the speed vs time curve becomes very unpredictable and noisy to give a linear position. It was working well initially when I had linear speed and parabolic position curve, but now its malfunctioning. Please suggest what I could be doing wrong. Could it be because I have shifted from current to voltage excitations?n -
March 16, 2021 at 2:43 pm
Navya C
Ansys EmployeeHi @ ChaitanyaDS,nCan you provide some screenshots along with the issue you are describing?nCan you elaborate on speed vs time curve becomes very unpredictable and noisy to give a linear positionAlso, what is your initial setup and current setup look like?nAs we can't access your model this information will help us interpret and investigate the problem better.nRegardsnNavyan
Trending discussions
- Maxwell, HFSS or Q3D?
- Error
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
