December 1, 2019 at 12:53 pm
Maurice
SubscriberHello,
I have a question about the time settings. In the picture I have defined the first 10 time steps, which are all the same. Is there a way to define a time step and define all following ones with the same settings(yellow fields)?
Thanks for your help!
December 1, 2019 at 1:45 pm
SubscriberHello Maurice,
In future posts, please use the Insert Image button to place images directly into the post.
Don't use 180 as the number of steps, use 1 step.
You might have 180 data points or you might want the simulation to run for 180 seconds, make 180 the end time.
You can change Define By from Time to Substeps, then for Initial and Minimum Substeps you can have 180.
December 1, 2019 at 2:04 pm
Maurice
SubscriberHello peteroznewman,
thank you very much for your answer, I have tested it and it works perfectly fine.
December 1, 2019 at 3:25 pm
SubscriberGreat Maurice,
Please click the Is Solution link to mark this Discussion as Solved.
3311
2471
