November 10, 2023 at 10:29 am
kobay000
SubscriberHi, I have been trying to verify a 5-phase interior permanent magnet machine with Ansys Maxwell. However, the analysis results do not match. The initial position (d-axis of magnets which are colored red) has aligned with the Phase-A coil (which is colored dark and light red in slots).
The winding excitations are defined as below:
A = id*sin(thet_e)+iq*cos(thet_e)
B = id*sin(thet_e-2*pi/5)+iq*cos(thet_e-2*pi/5)
C = id*sin(thet_e-4*pi/5)+iq*cos(thet_e-4*pi/5)
D = id*sin(thet_e-6*pi/5)+iq*cos(thet_e-6*pi/5)
E = id*sin(thet_e-8*pi/5)+iq*cos(thet_e-8*pi/5)
id = -50
iq = 20
thet_e = Omega_rad*Time
Omega_rad = 3141
However, the calculated id and iq currents do not match with given values.
Also, when I try to calculate the torque with calculated Ld, Lq, id, and iq it does not match with the torque calculated by Ansys which is given below. Please, any help or suggestions?
November 14, 2023 at 2:22 pm
Aymen
Ansys EmployeePlease contact Ansys Support customer.ansys.com and upload your design for further investigation
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8808
4658
3151
1680
1470
