November 19, 2018 at 12:35 pm
November 19, 2018 at 1:11 pm
Keyur Kanade
Ansys EmployeeYou will need a line to plot. For this please create a line using Insert - Location - Line. Then use this line for plot.
If this is the solution, please mark this as 'Is Solution' to help others on forum
November 19, 2018 at 1:50 pm
November 19, 2018 at 1:59 pm
DrAmine
Ansys EmployeeYou cannot select line for transient chart. Only points are available as you want to plot something against time at certain position.
What do you want to do?
November 19, 2018 at 2:07 pm
gowthamdada
Subscribervelocity vs time chart
November 19, 2018 at 2:09 pm
DrAmine
Ansys EmployeeYou can define an expression for length average of the velocity at the line or you create some points along the line and plot the velocity versus time @ the points!
November 19, 2018 at 3:32 pm
gowthamdada
Subscriber -
November 19, 2018 at 4:09 pm
DrAmine
Ansys EmployeeYou can check in the help for the above mentioned suggestions.
For pig Wall: You just define the line or just use the of boundary at it is, create an expression say areaAve(Velocity)@Pig and then use that expression to plot a transient chart. Just look in the help after "Quantitative Function List".
November 20, 2018 at 4:27 am
Keyur Kanade
Ansys EmployeeI overlooked it. As it is transient simulation, you will have to use points as Amine mentioned.
2688
2138
1355
1140
462
