October 30, 2023 at 8:39 pm
bv169
SubscriberGood afternoon,
I am running an MHD model with a set external field and a static velocity field. I am running it in transient. When doing so, there is no development in the magnetic field. I set monitors that showed the field is unchanged. What could be the cause of this?
Thanks,
Breanna
November 7, 2023 at 6:28 pm
bv169
SubscriberFollowing up as this has not been resolved.
November 13, 2023 at 12:46 pm
Ulrich
Ansys EmployeeTo be honest I am not sure whether I fully understand what you are doing or expecting.
You have an external magnetic field. I presume that this is static. Is that correct?
In addition, you have a static velocity field.
If I have a static magnetic field and a static velocity field, I am not sure why I should expect transient changes.
November 14, 2023 at 6:05 pm
bv169
SubscriberThe interaction of the initial constant flow with the magnetic field induces another magnetic field which is the one we've been plotting and doesn't seem to evolve as our analytic solution predicts. The flow field itself should be affected (very slightly) by the Lorentz force. So in summary, the magnetic and velocity fields are indeed initially constant but evolve because of the coupling of the equations into something (in our case slightly) different, but they are not static. But we do not see this in the Fluent MHD model.
November 17, 2023 at 2:32 pm
Ulrich Schmidt
SubscriberI would start with running MHD in stationary. Do you get reasonable results in stationary (e. g. induced magnetic field )?
Which settings have you chosen for the MHD Model (MHD Method, value of external field …)? Perhaps you can add some screenshots here.
Which time step have you chosen? How long have you calculated?
November 20, 2023 at 7:17 pm
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1688
1478
