October 13, 2018 at 3:30 am
sharm2a2
SubscriberI am running unsteady flow in a pipe and and I am not getting periodic behavior in residual. The residuals are just decreasing as if it's a steady flow.
Can anyone explain why?
Thanks
October 13, 2018 at 6:17 am
DrAmine
Ansys EmployeeYou can imagine that an unsteady analysis is a set of steady state runs. So every transient will be started by the result of the steady state result coressponding to previous time step. If the initialization is so good snd/or the taylor extrapolation is doing right then the periodic pattern won't appear. Check the behavior of monitor points within a time step along the number of iterations. Uncheck at first convergence by residuals for understanding a transient loop with at least 3 inner coefficents liniarization is important
October 15, 2018 at 12:41 am
sharm2a2
SubscriberHi Abenhadj
Thank you very much
2524
2066
1279
1096
459
