Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
transient simulation electrical heating
    • Dang-Cuong Phan
      How to carry out transient thermal electrical caculation in workbench 2022?
    • Sampat Kumar
      Hi Dang,
      Will you please explain the problem in detail? it's not clear from the above-mentioned detail what type of module you want to use. Please explain the problem in the detail so that we can suggest how can be your simulation flow or which module would be suitable for your analysis.
      Sampat
    • Dang-Cuong Phan
      I simulate the heating process in a furnace, using electrical  energy (applying a voltage on an Ohm-resitance).
      In workbench 2022R1 I can only set up a stationary process. My process is transient. The temperatur in furnace  should increas by time.
      Howe can I create a transient simulation of thermal electrical heating process in workbench?
    • Sampat Kumar
      Hi Dang,
      We have transient thermal and transient structural modules in the Ansys workbench to perform the simulation with respect to time. I have highlighted the module in the image.
      Please let me know if you have nay issues related to it.
      Sampat
    • Dang-Cuong Phan
      Hi Sampat, I need transient calculation of electrical heating process, transient thermal simulation alone is useless in my project. In ansys classic the couppling electrical-thermal is standard and works well.
Viewing 4 reply threads
