Transient soulation
    • nmshekhawat
      I am working on SCIM eccentric fault model. till now I have simulated a healthy motor by using rm-expert and convert it into 2D model but I don't know how to introduce this fault in my model is it possible directly to create an offset  ?? I try t create a relative CS for the rotor position and the motion set-up by analysing it was ok but the local solution of a motor is not completing they are showing error like no face are available.
    • nmshekhawat
    • Andrei
      If you install version 19.2 you can go to Automation menu, Show/Hide ACT Extensions, Launch Wizards, Maxwell Eccentricity toolbox
    • nmshekhawat
      is it available in a student version?
Viewing 3 reply threads
