March 18, 2022 at 10:05 am
El_Manguangua
SubscriberI'm thinking in terms of the Courant number that relates the mesh size with the time step.
I'm also wondering if there are internal mechanisms in Ansys that should be taken into consideration for the operator (me) to select a time step.
I don't know if this would be relevant, bot I'm studying an Fluid-Solid iIteraction (FSI) between an aircraft wing and air, and the meshing varies depending on the part of the wing.
Thank you in advance!
March 21, 2022 at 4:05 pmAshish Khemka
Please see if the following link helps:
Guidelines for Integration Step Size (ansys.com)
Regards Ashish Khemka
2656
2120
1347
1118
461
