Transient Thermal – Analysis setting – Time step
    • klemen1991
      Dear all,
      I'm having a problem with correctly setting the transient settings for my PV module. I'm trying to calculate time dependency of temperature on the backside of my PV module. I was using the tabular data of thin coeficient (convection), wind speed (convection) and heat flux (radiation) on the front side of the PV module.
      I have the measurements of all those parameters, but I'm having trouble setting the time dependency of temperature. I have half-hour measurement (which means 48 measurements of all three parameters) and I would like to calculate temperature for each measurements (48 values for temperature).
      I was looking at some old posts, but I'm not sure if I'm doing it right. Below you can see my case.
      Can someone please help me.
      Thank you in advance.
    • Daniel Shaw
      You to change Auto Time Stepping from Programmed Controlled to Off and then specify 48 solution steps.n
