Transient thermal simulation using moving heat source but only 1 data calculated
    • Chan Hyung Ryu
      Question 1. When using 2 Moving Heat Flux at the same time, only 1 can be used.
      It doesn't make any sense. I'm not sure why
      Question 2. In addition, errors and warnings appeared in the solution information.
      Question 3. I heard that the heat source of the moving heat source is Gaussian, is that correct?
      Question 4. Can I put the value of 20mm/s as a -value to reverse the direction of the moving heat source? If not, please tell me how to specify directionality
      please tell me as detail as possible
      thanks your help
      Solver Output
       Ansys Mechanical Enterprise Academic Student
       |   W E L C O M E   T O   T H E   A N S Y S (R)  P R O G R A M     |
       *         ANSYS MAPDL 2023 R1          LEGAL NOTICES          *
       * Copyright 1971-2023 Ansys, Inc.  All rights reserved.       *
       * Unauthorized use, distribution or duplication is            *
       * prohibited.                                                 *
       * Ansys is a registered trademark of Ansys, Inc. or its       *
       * subsidiaries in the United States or other countries.       *
       * See the Ansys, Inc. online documentation or the Ansys, Inc. *
       * documentation CD or online help for the complete Legal      *
       * Notice.                                                     *
       * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION       *
       * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY      *
       * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.    *
       * The software products and documentation are furnished by    *
       * Ansys, Inc. or its subsidiaries under a software license    *
       * agreement that contains provisions concerning               *
       * non-disclosure, copying, length and nature of use,          *
       * compliance with exporting laws, warranties, disclaimers,    *
       * limitations of liability, and remedies, and other           *
       * provisions.  The software products and documentation may be *
       * used, disclosed, transferred, or copied only in accordance  *
       * with the terms and conditions of that software license      *
       * agreement.                                                  *
       * Ansys, Inc. is a UL registered                              *
       * ISO 9001:2015 company.                                      *
       * This product is subject to U.S. laws governing export and   *
       * re-export.                                                  *
       * For U.S. Government users, except as specifically granted   *
       * by the Ansys, Inc. software license agreement, the use,     *
       * duplication, or disclosure by the United States Government  *
       * is subject to restrictions stated in the Ansys, Inc.        *
       * software license agreement and FAR 12.212 (for non-DOD      *
       * licenses).                                                  *
       2023 R1
       Point Releases and Patches installed:
       Discovery 2023 R1
       Autodyn 2023 R1
       SpaceClaim 2023 R1
       CFX (includes CFD-Post) 2023 R1
       Chemkin 2023 R1
       EnSight 2023 R1
       FENSAP-ICE 2023 R1
       Fluent (includes CFD-Post) 2023 R1
       Polyflow (includes CFD-Post) 2023 R1
       Forte (includes EnSight) 2023 R1
       TurboGrid 2023 R1
       Aqwa 2023 R1
       Speos 2023 R1
       Mechanical Products 2023 R1
       Material Calibration App 2023 R1
       ACIS Geometry Interface 2023 R1
       AutoCAD Geometry Interface 2023 R1
       Catia, Version 4 Geometry Interface 2023 R1
       Catia, Version 5 Geometry Interface 2023 R1
       Catia, Version 6 Geometry Interface 2023 R1
       Creo Elements/Direct Modeling Geometry Interface 2023 R1
       Creo Parametric Geometry Interface 2023 R1
       Inventor Geometry Interface 2023 R1
       JTOpen Geometry Interface 2023 R1
       NX Geometry Interface 2023 R1
       Parasolid Geometry Interface  2023 R1
       Solid Edge Geometry Interface 2023 R1
       SOLIDWORKS Geometry Interface 2023 R1
       Academic Student 2023 R1
                *****  MAPDL COMMAND LINE ARGUMENTS  *****
        BATCH MODE REQUESTED (-b)    = NOLIST
        INPUT FILE COPY MODE (-c)    = COPY
        DISTRIBUTED MEMORY PARALLEL REQUESTED
             4 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
          TOTAL OF     4 CORES REQUESTED
        INPUT FILE NAME              = C:\Users\candt\AppData\Local\Temp\WB_candt_12860_2\_ProjectScratch\ScrE60B\dummy.dat
        OUTPUT FILE NAME             = C:\Users\candt\AppData\Local\Temp\WB_candt_12860_2\_ProjectScratch\ScrE60B\solve.out
        START-UP FILE MODE           = NOREAD
        STOP FILE MODE               = NOREAD
       RELEASE= 2023 R1              BUILD= 23.1      UP20221128   VERSION=WINDOWS x64
       CURRENT JOBNAME=file0  14:13:59  JAN 26, 2023 CP=      0.047
       PARAMETER _DS_PROGRESS =     999.0000000
       /INPUT FILE= ds.dat  LINE=       0
       *** NOTE ***                            CP =       0.109   TIME= 14:14:00
       The /CONFIG,NOELDB command is not valid in a distributed memory
       parallel solution.  Command is ignored.
       *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  14.2333333
       TITLE=
       wbnew--Transient Thermal (A5)
        ACT Extensions:
            MovingHeat, 4.1
            dc7b91d1-0fd6-439f-811e-316ced903703, wbex
       /COM,     LSDYNA, 2023.1
            5f463412-bd3e-484b-87e7-cbc0a665e474, wbex
       /COM,     ANSYSMotion, 2023.1
            20180725-3f81-49eb-9f31-41364844c769, wbex
       SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR
        TYPE=STRI  DIMENSIONS=      248        1        1
       PARAMETER _WB_PROJECTSCRATCH_DIR(1) = C:\Users\candt\AppData\Local\Temp\WB_candt_12860_2\_ProjectScratch\ScrE60B\
       SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR
       PARAMETER _WB_SOLVERFILES_DIR(1) = C:\Users\candt\AppData\Local\Temp\WB_candt_12860_2\wbnew_files\dp0\SYS\MECH\
       SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR
       PARAMETER _WB_USERFILES_DIR(1) = C:\Users\candt\AppData\Local\Temp\WB_candt_12860_2\wbnew_files\user_files\
       --- Data in consistent NMM units. See Solving Units in the help system for more
       MPA UNITS SPECIFIED FOR INTERNAL
        LENGTH      = MILLIMETERS (mm)
        MASS        = TONNE (Mg)
        TIME        = SECONDS (sec)
        TEMPERATURE = CELSIUS (C)
        TOFFSET     = 273.0
        FORCE       = NEWTON (N)
        HEAT        = MILLIJOULES (mJ)
       INPUT  UNITS ARE ALSO SET TO MPA
       *** MAPDL - ENGINEERING ANALYSIS SYSTEM  RELEASE 2023 R1          23.1     ***
       01055371  VERSION=WINDOWS x64   14:14:00  JAN 26, 2023 CP=      0.141
                ***** MAPDL ANALYSIS DEFINITION (PREP7) *****
       *********** Nodes for the whole assembly ***********
       *********** Elements for Body 1 "SYS\Solid" ***********
       *********** Send User Defined Coordinate System(s) ***********
       *********** Send Materials ***********
       *********** Create "Convection" ***********
       ***************** Define Uniform Initial temperature ***************
       ***** ROUTINE COMPLETED *****  CP =         0.203
       --- Number of total nodes = 24107
       --- Number of contact elements = 4980
       --- Number of spring elements = 0
       --- Number of bearing elements = 0
       --- Number of solid elements = 14212
       --- Number of condensed parts = 0
       --- Number of total elements = 19192
       *GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  14.2333333
       *************************    SOLUTION       ********************************
       *****  MAPDL SOLUTION ROUTINE  *****
       PERFORM A TRANSIENT ANALYSIS
        THIS WILL BE A NEW ANALYSIS
       STEP BOUNDARY CONDITION KEY= 1
       CONTACT INFORMATION PRINTOUT LEVEL       1
       DO NOT SAVE ANY RESTART FILES AT ALL
       DO NOT COMBINE ELEMENT MATRIX FILES (.emat) AFTER DISTRIBUTED PARALLEL SOLUTION
       DO NOT COMBINE ELEMENT SAVE DATA FILES (.esav) AFTER DISTRIBUTED PARALLEL SOLUTION
       Use Quasi-Linear Thermal Transient Solution
         Tolerance for Reform of Thermal Matrix=     0.050
         ***** Fast Property Table Information *****
          Number of entries per property=    64
          Minimum temperature =      0.00
          Maximum temperature =   1000.00
        Enable multipass algorithm
       *** WARNING ***                         CP =       0.203   TIME= 14:14:00
       Temperature-dependent properties have not been specified.  The
       THOPT,QUASI option does not perform equilibrium iterations.  Small
       time steps may be required to obtain accurate results.
       NLHIST: ADDED NODAL RESULTS HISTORY FOR:
             NAME = MAX_TEMP
        ITEM/COMP = TEMPMAX
             NODE =         0
             NAME = MIN_TEMP
        ITEM/COMP = TEMPMIN
             NODE =         0
       ********* Initial Time Increment Check And Fourier Modulus *********
        Specified Initial Time Increment: 0.1
        Estimated Increment Needed, le*le/alpha, Body 1: 0.0131295
       ******************* SOLVE FOR LS 1 OF 1 ****************
       SELECT       FOR ITEM=TYPE COMPONENT=
        IN RANGE         2 TO          2 STEP          1
             4980  ELEMENTS (OF      19192  DEFINED) SELECTED BY  ESEL  COMMAND.
       SELECT      ALL NODES HAVING ANY ELEMENT IN ELEMENT SET.
             9962 NODES (OF      24107  DEFINED) SELECTED FROM
           4980 SELECTED ELEMENTS BY NSLE COMMAND.
       GENERATE SURFACE LOAD CONV ON SURFACE DEFINED BY ALL SELECTED NODES
       VALUES=_CONVVARI35  22.0000000
       NUMBER OF CONV ELEMENT FACE LOADS STORED =       4980
       ALL SELECT   FOR ITEM=NODE COMPONENT=
        IN RANGE         1 TO      24107 STEP          1
            24107  NODES (OF      24107  DEFINED) SELECTED BY NSEL  COMMAND.
       ALL SELECT   FOR ITEM=ELEM COMPONENT=
        IN RANGE         1 TO      24172 STEP          1
            19192  ELEMENTS (OF      19192  DEFINED) SELECTED BY  ESEL  COMMAND.
       PRINTOUT RESUMED BY /GOP
       USE AUTOMATIC TIME STEPPING THIS LOAD STEP
       USE INITIAL TIME STEP SIZE OF 0.1000000     FOR ALL  DEGREES OF FREEDOM
       FOR AUTOMATIC TIME STEPPING:
         USE 0.1000000E-01 AS THE MINIMUM TIME STEP SIZE
         USE 0.1000000     AS THE MAXIMUM TIME STEP SIZE
       TIME=  4.0000
       INCLUDE TRANSIENT EFFECTS FOR  ALL DEGREES OF FREEDOM THIS LOAD STEP
       ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
       WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
         FOR ALL APPLICABLE ENTITIES
       WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE EANG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE VENG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE FFLU ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE CONT ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE MISC ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
         FOR THE ENTITIES DEFINED BY COMPONENT _ELMISC
       CONVERGENCE ON HEAT BASED ON THE NORM OF THE N-R LOAD
         WITH A TOLERANCE OF 0.1000E-02 AND A MINIMUM REFERENCE VALUE OF 0.1000E-02
         USING THE L2 NORM (CHECK THE SRSS VALUE)
       *********** Moving Heat Flux: Moving Heat Flux ***********
       FINISH SOLUTION PROCESSING
       ***** ROUTINE COMPLETED *****  CP =         0.219
       01055371  VERSION=WINDOWS x64   14:14:00  JAN 26, 2023 CP=      0.219
       CMBLOCK read of NODE component FACE1     completed
       CMBLOCK read of NODE component PATH1     completed
       CMBLOCK read of NODE component START1    completed
       You have already entered the general preprocessor (PREP7).
       SELECT ALL ENTITIES OF TYPE= ALL  AND BELOW
       PARAMETER INX =     1.000000000
       PARAMETER LSTP =     200.0000000
       PARAMETER VEL =     20.00000000
       PARAMETER SEG =     201.0000000
       PARAMETER R1 =     1.600000000
       PARAMETER LD =     156250.0000
       PARAMETER TM_L =     2.000000000
       PARAMETER TM_S =     0.000000000
       PARAMETER FP = Yes
       *IF  FP                                ( = Yes              )  EQ
            Yes                               ( = Yes              )  THEN
       OPENED FILE= INDEX1.TXT FOR COMMAND FILE DATA
        COMMAND FILE CLOSED
       OPENED FILE= VELOCITY1.TXT FOR COMMAND FILE DATA
        COMMAND FILE CLOSED
       OPENED FILE= LSTP1.TXT FOR COMMAND FILE DATA
        COMMAND FILE CLOSED
       OPENED FILE= CON1.TXT FOR COMMAND FILE DATA
        COMMAND FILE CLOSED
       OPENED FILE= LD1.TXT FOR COMMAND FILE DATA
        COMMAND FILE CLOSED
       OPENED FILE= TMST1.TXT FOR COMMAND FILE DATA
        COMMAND FILE CLOSED
       OPENED FILE= TMLT1.TXT FOR COMMAND FILE DATA
        COMMAND FILE CLOSED
       *ELSEIF  FP                                ( = Yes              )  EQ
                No                                ( = No               )  THEN
       *ELSE
       *ENDIF
       PARAMETER NLINE    =         1.000000
       SET PARAMETER DIMENSIONS ON  INDEX TYPE=ARRA  DIMENSIONS=     1     1     1
       SET PARAMETER DIMENSIONS ON  VELOCITY TYPE=ARRA  DIMENSIONS=     1     1     1
       SET PARAMETER DIMENSIONS ON  LSTP TYPE=ARRA  DIMENSIONS=     1     1     1
       *** WARNING ***                         CP =       0.219   TIME= 14:14:00
       Parameter LSTP already exists.  It is deleted and redefined by the *DIM
       command.
       SET PARAMETER DIMENSIONS ON  R1 TYPE=ARRA  DIMENSIONS=     1     1     1
       Parameter R1 already exists.  It is deleted and redefined by the *DIM
       command.
       SET PARAMETER DIMENSIONS ON  LD TYPE=ARRA  DIMENSIONS=     1     1     1
       Parameter LD already exists.  It is deleted and redefined by the *DIM
       command.
       SET PARAMETER DIMENSIONS ON  TMST TYPE=ARRA  DIMENSIONS=     1     1     1
       SET PARAMETER DIMENSIONS ON  TMLT TYPE=ARRA  DIMENSIONS=     1     1     1
       VECTOR READ OPERATION  *VREAD
        INDEX    READ FROM FILE INDEX1.TXT
       VECTOR LENGTH=      1
       LOOP DIRECTIONS=IJK   COUNTS=       1       1       1
       FORMAT=(f3.0)
        VELOCITY READ FROM FILE VELOCITY1.TXT
       VECTOR LENGTH=      1
       FORMAT=(f10.5)
        LSTP     READ FROM FILE LSTP1.TXT
       VECTOR LENGTH=      1
       FORMAT=(f3.0)
        R1       READ FROM FILE CON1.TXT
       VECTOR LENGTH=      1
       FORMAT=(f10.5)
        LD       READ FROM FILE LD1.TXT
       VECTOR LENGTH=      1
       FORMAT=(f30.3)
        TMST     READ FROM FILE TMST1.TXT
       VECTOR LENGTH=      1
       FORMAT=(f10.5)
        TMLT     READ FROM FILE TMLT1.TXT
       VECTOR LENGTH=      1
       FORMAT=(f10.5)
       *DO LOOP ON PARAMETER= INC1 FROM  1.0000     TO  1.0000     BY  1.0000
       *IF  INC1                              ( =   1.00000     )  EQ
            1                                 ( =   1.00000     )  THEN
       SELECT      COMPONENT FACE1
       *ELSE
       *ENDIF
       *ENDDO  INDEX= INC1
       DEFINITION OF COMPONENT = FACE      ENTITY=NODE
       SELECT      COMPONENT PATH1
       *GET  PT_ND1    FROM  NODE  ITEM=COUN       VALUE=  81.0000000
       SET PARAMETER DIMENSIONS ON  N_PT1 TYPE=ARRA  DIMENSIONS=    81     1     1
       SET PARAMETER DIMENSIONS ON  X_PT1 TYPE=ARRA  DIMENSIONS=    81     1     1
       SET PARAMETER DIMENSIONS ON  Y_PT1 TYPE=ARRA  DIMENSIONS=    81     1     1
       SET PARAMETER DIMENSIONS ON  Z_PT1 TYPE=ARRA  DIMENSIONS=    81     1     1
       SET PARAMETER DIMENSIONS ON  PT_LEN1 TYPE=ARRA  DIMENSIONS=    81     1     1
       SELECT      COMPONENT START1
       *GET  ND1       FROM  NODE  ITEM=NUM  MIN   VALUE=  286.000000
       PARAMETER PT_LEN1(1,1) =     0.000000000
       *DO LOOP ON PARAMETER= INC2 FROM  1.0000     TO  81.000     BY  1.0000
       PARAMETER N_PT1(INC2,1) =     286.0000000
       PARAMETER X_PT1(INC2,1) =     5.000000000
       PARAMETER Y_PT1(INC2,1) =     0.000000000
       PARAMETER Z_PT1(INC2,1) =    -10.00000000
       PARAMETER ND2 =     5488.000000
       *IF  INC2                              ( =   1.00000     )  NE
            PT_ND%INDEX(INC1,1)%              ( =   81.0000     )  THEN
       PARAMETER PT_LEN1(INC2+1,1) =    0.5000000000
       *ENDIF
       UNSELECT     FOR ITEM=NODE COMPONENT=
        IN RANGE       286 TO        286 STEP          1
               80  NODES (OF      24107  DEFINED) SELECTED BY  NSEL  COMMAND.
       PARAMETER ND1 =     5488.000000
       *ENDDO  INDEX= INC2
       PARAMETER TOT_LEN1 =     40.00000000
       PARAMETER VEL_M1 =     20.00000000
       *ENDDO  INDEX= INC1
       VECTOR PARAMETER OPERATION *VSCFUN
        MAX_T    = MAX  TMLT
       VECTOR LENGTH=       1
       RESULT=  2.0000
        MIN_T    = MIN  TMST
       VECTOR LENGTH=       1
       RESULT=  0.0000
       PARAMETER DT =    0.1000000000E-01
       SET PARAMETER DIMENSIONS ON  T_NR TYPE=ARRA  DIMENSIONS=   201     1     1
       SET PARAMETER DIMENSIONS ON  P1 TYPE=ARRA  DIMENSIONS=   201     1     1
       VECTOR FILL OPERATION  *VFILL
        T_NR             = RAMP
       VECTOR LENGTH=     201
       INITIAL VALUE=  0.0000      STEP INCREMENT= 0.10000E-01
       VECTOR PARAMETER OPERATION *VOPER
        P1               = T_NR             GE   TM_S
        VECTOR LENGTH=     201
        TS1      = FIRS P1
       VECTOR LENGTH=     201
       RESULT=  1.0000
       PARAMETER TM_E =     2.000000000
        P1               = T_NR             GE   TM_E
        VECTOR LENGTH=     201
        TE1      = FIRS P1
       VECTOR LENGTH=     201
       RESULT=  201.00
       PARAMETER STATUS- TS1  (     57 PARAMETERS DEFINED)
                        (INCLUDING       22 INTERNAL PARAMETERS)
       NAME                              VALUE                        TYPE  DIMENSIONS
       TS1                               1.00000000                  SCALAR
       PARAMETER STATUS- TE1  (     57 PARAMETERS DEFINED)
       TE1                               201.000000                  SCALAR
       *ENDDO  INDEX= INC1
       *GET  NDT       FROM  NODE  ITEM=COUN       VALUE=  24107.0000
       SET PARAMETER DIMENSIONS ON  VARY_LD TYPE=ARRA  DIMENSIONS= 24107     1     1
       SET PARAMETER DIMENSIONS ON  X_LOC TYPE=ARRA  DIMENSIONS= 24107     1     1
       SET PARAMETER DIMENSIONS ON  Y_LOC TYPE=ARRA  DIMENSIONS= 24107     1     1
       SET PARAMETER DIMENSIONS ON  Z_LOC TYPE=ARRA  DIMENSIONS= 24107     1     1
       VECTOR GET OPERATION  X_LOC  VECTOR LENGTH=   24107
       NAME= NODE         0  LOC   X
       VECTOR GET OPERATION  Y_LOC  VECTOR LENGTH=   24107
       NAME= NODE         0  LOC   Y
       VECTOR GET OPERATION  Z_LOC  VECTOR LENGTH=   24107
       NAME= NODE         0  LOC   Z
       VECTOR GET OPERATION  NMASK  VECTOR LENGTH=   24107
       NAME= NODE         0  NSEL
        NMASK_1          = NMASK            ADD  1
        NMASK1           = NMASK_1          DIV  2
       *ENDDO  INDEX= INC1
       *GET  MAX_TYP   FROM  ETYP  ITEM=NUM  MAX   VALUE=  2.00000000
       *GET  MAX_MAT   FROM  MAT   ITEM=NUM  MAX   VALUE=  1.00000000
       *GET  MAX_RL    FROM  RCON  ITEM=NUM  MAX   VALUE= 0.788860905E-30
       ELEMENT TYPE          3 IS SURF152      3-D THERMAL SURFACE
        KEYOPT( 1- 6)=        0      0      0        0      0      0
        KEYOPT( 7-12)=        0      0      0        0      0      0
        KEYOPT(13-18)=        0      0      0        0      0      0
       CURRENT NODAL DOF SET IS  TEMP
        THREE-DIMENSIONAL MODEL
        KEYOPT( 7-12)=        0      1      0        0      0      0
       ELEMENT TYPE SET TO         3
       MATERIAL NUMBER SET TO         2
       REAL CONSTANT NUMBER=        1
       GENERATE ELEMENTS ON SURFACE DEFINED BY SELECTED NODES
        TYPE=        3  REAL=        1  MATERIAL=        2  ESYS=    0
       NUMBER OF ELEMENTS GENERATED=       2204
       PARAMETER EXT      =         0.000000
       *IF  EXT                               ( =   0.00000     )  EQ
       *ENDIF
       *ENDIF
       ***** ROUTINE COMPLETED *****  CP =         0.250
       *DO LOOP ON PARAMETER= INC1 FROM  1.0000     TO  201.00     BY  1.0000
       *DO LOOP ON PARAMETER= INC2 FROM  1.0000     TO  1.0000     BY  1.0000
       *IF  INC1                              ( =   1.00000     )  GE
            TS%INDEX(INC2,1)%                 ( =   1.00000     )
       *****  AND   *****
            INC1                              ( =   1.00000     )  LE
            TE%INDEX(INC2,1)%                 ( =   201.000     )  THEN
       PARAMETER DIST_11 =     0.000000000
       PARAMETER DIST_21 =     0.000000000
       PARAMETER DIST1 =     0.000000000
        LOC11            = PT_LEN1          GE   DIST1
        VECTOR LENGTH=      81
        LOC21    = FIRS LOC11
       VECTOR LENGTH=      81
       RESULT=  1.0000
       PARAMETER LOC31 =     0.000000000
       PARAMETER A0 =     81.00000000
            TS%INDEX(INC2,1)%                 ( =   1.00000     )  THEN
       PARAMETER A =     5.000000000
       PARAMETER B =     0.000000000
       PARAMETER C =    -10.00000000
       *ELSEIF  INC1                              ( =   1.00000     )  EQ
       *ELSE
       *ENDIF
        A1               = X_LOC            SUB  A
        B1               = Y_LOC            SUB  B
        C1               = Z_LOC            SUB  C
        A2               = A1               MULT A1
        B2               = B1               MULT B1
        C2               = C1               MULT C1
        A3               = A2               ADD  B2
        B3               = A3               ADD  C2
       PARAMETER R2 =    -2.560000000
        A4               = B3               DIV  R2
       VECTOR PARAMETER OPERATION *VFUN
        B4 = EXP   A4
       PARAMETER AA1 =     156250.0000
        L_D1             = AA1              MULT B4
        VARY_LD1         = L_D1             MULT NMASK1
        VARY_LD          = VARY_LD          ADD  VARY_LD1
       *ENDIF
       *ENDDO  INDEX= INC2
       USE THE VECTOR  VARY_LD   AS SURFACE LOAD FUNCTION
        IN RANGE         3 TO          3 STEP          1
             2204  ELEMENTS (OF      21396  DEFINED) SELECTED BY  ESEL  COMMAND.
       SPECIFIED SURFACE LOAD HFLU FOR ALL SELECTED ELEMENTS  LKEY = 1
           VALUES =     0.0000         0.0000         0.0000         0.0000
       PARAMETER TM =    0.1000000000E-01
       TIME= 0.10000E-01
       USE     1 SUBSTEP(S) THIS LOAD STEP FOR ALL  DEGREES OF FREEDOM
       *** NOTE ***                            CP =       0.359   TIME= 14:14:00
       The automatic domain decomposition logic has selected the MESH domain
       decomposition method with 4 processes per solution.
       *****  MAPDL SOLVE    COMMAND  *****
       *** WARNING ***                         CP =       0.359   TIME= 14:14:00
       Element shape checking is currently inactive.  Issue SHPP,ON or
       SHPP,WARN to reactivate, if desired.
       The model data was checked and warning messages were found.
        Please review output or errors file (
       E60B\file0.err ) for these warning messages.
       01055371  VERSION=WINDOWS x64   14:14:00  JAN 26, 2023 CP=      0.375
                             S O L U T I O N   O P T I O N S
         PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
         DEGREES OF FREEDOM. . . . . . TEMP
         ANALYSIS TYPE . . . . . . . . . . . . . . . . .TRANSIENT
            SOLUTION METHOD. . . . . . . . . . . . . . .QUASI
         OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . .  273.15
         NEWTON-RAPHSON OPTION . . . . . . . . . . . . .PROGRAM CHOSEN
         GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC
       *** WARNING ***                         CP =       0.375   TIME= 14:14:00
       Material number 2 (used by element 19193) should normally have at least
       one MP or one TB type command associated with it.  Output of energy by
       material may not be available.
       *** NOTE ***                            CP =       0.391   TIME= 14:14:00
       The step data was checked and warning messages were found.
       The conditions for direct assembly have been met.  No .emat or .erot
       files will be produced.
           D I S T R I B U T E D   D O M A I N   D E C O M P O S E R
        ...Number of elements: 21396
        ...Number of nodes:    24107
        ...Decompose to 4 CPU domains
        ...Element load balance ratio =     1.005
                            L O A D   S T E P   O P T I O N S
         LOAD STEP NUMBER. . . . . . . . . . . . . . . .     1
         TIME AT END OF THE LOAD STEP. . . . . . . . . . 0.10000E-01
         AUTOMATIC TIME STEPPING . . . . . . . . . . . .    ON
            INITIAL NUMBER OF SUBSTEPS . . . . . . . . .     1
            MAXIMUM NUMBER OF SUBSTEPS . . . . . . . . .     1
            MINIMUM NUMBER OF SUBSTEPS . . . . . . . . .     1
         MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS. . . .    15
         STEP CHANGE BOUNDARY CONDITIONS . . . . . . . .   YES
         TRANSIENT (INERTIA) EFFECTS
            THERMAL DOFS . . . . . . . . . . . . . . . .    ON
         TRANSIENT INTEGRATION PARAMETERS
            THETA. . . . . . . . . . . . . . . . . . . .  1.0000
            OSCILLATION LIMIT CRITERION. . . . . . . . . 0.50000
            TOLERANCE. . . . . . . . . . . . . . . . . .  0.0000
         TERMINATE ANALYSIS IF NOT CONVERGED . . . . . .YES (EXIT)
         CONVERGENCE CONTROLS
            LABEL   REFERENCE    TOLERANCE  NORM     MINREF
             HEAT    0.000       0.1000E-02   2     0.1000E-02
         PRINT OUTPUT CONTROLS . . . . . . . . . . . . .NO PRINTOUT
         DATABASE OUTPUT CONTROLS
            ITEM     FREQUENCY   COMPONENT
             ALL       NONE
            NSOL        ALL
            RSOL        ALL
            EANG        ALL
            VENG        ALL
            FFLU        ALL
            CONT        ALL
            MISC        ALL       _ELMISC
       SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr
                  **** CENTER OF MASS, MASS, AND MASS MOMENTS OF INERTIA ****
        CALCULATIONS ASSUME ELEMENT MASS AT ELEMENT CENTROID
        TOTAL MASS =  0.12560E-04
                                 MOM. OF INERTIA         MOM. OF INERTIA
        CENTER OF MASS            ABOUT ORIGIN        ABOUT CENTER OF MASS
        XC =   25.000          IXX =   0.1685E-02      IXX =   0.4206E-03
        YC = -0.80000          IYY =   0.1214E-01      IYY =   0.3035E-02
        ZC =  -10.000          IZZ =   0.1048E-01      IZZ =   0.2619E-02
                               IXY =   0.2512E-03      IXY =  -0.4186E-09
                               IYZ =  -0.1005E-03      IYZ =   0.5883E-09
                               IZX =   0.3140E-02      IZX =   0.8833E-10
        *** MASS SUMMARY BY ELEMENT TYPE ***
        TYPE      MASS
           1  0.125600E-04
       Range of element maximum matrix coefficients in global coordinates
       Maximum = 132.12988 at element 5428.
       Minimum = 1.840801884E-04 at element 21534.
         *** ELEMENT MATRIX FORMULATION TIMES
           TYPE    NUMBER   ENAME      TOTAL CP  AVE CP
              1     14212  SOLID291      0.203   0.000014
              2      4980  SURF152       0.047   0.000009
              3      2204  SURF152       0.016   0.000007
       Time at end of element matrix formulation CP = 0.59375.
       DISTRIBUTED SPARSE MATRIX DIRECT SOLVER.
        Number of equations =       24107,    Maximum wavefront =     76
        Process memory allocated for solver              =    13.268 MB
        Process memory required for in-core solution     =    12.741 MB
        Process memory required for out-of-core solution =     6.643 MB
        Total memory allocated for solver                =    52.041 MB
        Total memory required for in-core solution       =    49.966 MB
        Total memory required for out-of-core solution   =    25.768 MB
       *** NOTE ***                            CP =       0.719   TIME= 14:14:00
       The Distributed Sparse Matrix Solver is currently running in the
       in-core memory mode.  This memory mode uses the most amount of memory
       in order to avoid using the hard drive as much as possible, which most
       often results in the fastest solution time.  This mode is recommended
       if enough physical memory is present to accommodate all of the solver
       data.
       Distributed sparse solver maximum pivot= 278.345736 at node 11754 TEMP.
       Distributed sparse solver minimum pivot= 21.1551413 at node 146 TEMP.
       Distributed sparse solver minimum pivot in absolute value= 21.1551413
       at node 146 TEMP.
         *** ELEMENT RESULT CALCULATION TIMES
              1     14212  SOLID291      0.156   0.000011
              2      4980  SURF152       0.062   0.000013
              3      2204  SURF152       0.000   0.000000
         *** NODAL LOAD CALCULATION TIMES
              1     14212  SOLID291      0.141   0.000010
              2      4980  SURF152       0.016   0.000003
       *** LOAD STEP     1   SUBSTEP     1  COMPLETED.    CUM ITER =      1
       *** TIME =  0.100000E-01     TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  117.5       OSCILLATION LIMIT =  1.175
       *** MAPDL BINARY FILE STATISTICS
        BUFFER SIZE USED= 16384
              0.500 MB WRITTEN ON ELEMENT SAVED DATA FILE: file0.esav
              1.875 MB WRITTEN ON ASSEMBLED MATRIX FILE: file0.full
              2.250 MB WRITTEN ON RESULTS FILE: file0.rth
       *** WARNING ***                         CP =       0.953   TIME= 14:14:01
       Parameter VARY_LD already exists.  It is deleted and redefined by the
       *DIM command.
       *ENDDO  INDEX= INC1
       *** WARNING ***                         CP =       1.047   TIME= 14:14:01
       01055371  VERSION=WINDOWS x64   14:14:01  JAN 26, 2023 CP=      1.094
       *** LOAD STEP     2   SUBSTEP     1  COMPLETED.    CUM ITER =      2
       *** TIME =  0.200000E-01     TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  29.51       OSCILLATION LIMIT = 0.2951
       *** WARNING ***                         CP =       1.406   TIME= 14:14:01
       *DIM command.
       *** WARNING ***                         CP =       1.453   TIME= 14:14:01
       01055371  VERSION=WINDOWS x64   14:14:01  JAN 26, 2023 CP=      1.516
       *** LOAD STEP     3   SUBSTEP     1  COMPLETED.    CUM ITER =      3
       *** TIME =  0.300000E-01     TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.84       OSCILLATION LIMIT = 0.1884
       *** WARNING ***                         CP =       1.828   TIME= 14:14:02
       *DIM command.
       *** WARNING ***                         CP =       1.875   TIME= 14:14:02
       01055371  VERSION=WINDOWS x64   14:14:02  JAN 26, 2023 CP=      1.922
       *** LOAD STEP     4   SUBSTEP     1  COMPLETED.    CUM ITER =      4
       *** TIME =  0.400000E-01     TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  16.03       OSCILLATION LIMIT = 0.1603
       *** WARNING ***                         CP =       2.234   TIME= 14:14:02
       *DIM command.
       *** WARNING ***                         CP =       2.281   TIME= 14:14:02
       01055371  VERSION=WINDOWS x64   14:14:02  JAN 26, 2023 CP=      2.328
       *** LOAD STEP     5   SUBSTEP     1  COMPLETED.    CUM ITER =      5
       *** TIME =  0.500000E-01     TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  15.86       OSCILLATION LIMIT = 0.1586
       *** WARNING ***                         CP =       2.656   TIME= 14:14:03
       *DIM command.
       *** WARNING ***                         CP =       2.703   TIME= 14:14:03
       01055371  VERSION=WINDOWS x64   14:14:03  JAN 26, 2023 CP=      2.766
       *** LOAD STEP     6   SUBSTEP     1  COMPLETED.    CUM ITER =      6
       *** TIME =  0.600000E-01     TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  16.58       OSCILLATION LIMIT = 0.1658
       *** WARNING ***                         CP =       3.078   TIME= 14:14:03
       *DIM command.
       *** WARNING ***                         CP =       3.141   TIME= 14:14:03
       01055371  VERSION=WINDOWS x64   14:14:03  JAN 26, 2023 CP=      3.188
       *** LOAD STEP     7   SUBSTEP     1  COMPLETED.    CUM ITER =      7
       *** TIME =  0.700000E-01     TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  17.53       OSCILLATION LIMIT = 0.1753
       *** WARNING ***                         CP =       3.500   TIME= 14:14:03
       *DIM command.
       *** WARNING ***                         CP =       3.609   TIME= 14:14:03
       01055371  VERSION=WINDOWS x64   14:14:03  JAN 26, 2023 CP=      3.656
       *** LOAD STEP     8   SUBSTEP     1  COMPLETED.    CUM ITER =      8
       *** TIME =  0.800000E-01     TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.44       OSCILLATION LIMIT = 0.1844
       *** WARNING ***                         CP =       3.984   TIME= 14:14:04
       *DIM command.
       *** WARNING ***                         CP =       4.016   TIME= 14:14:04
       01055371  VERSION=WINDOWS x64   14:14:04  JAN 26, 2023 CP=      4.078
       *** LOAD STEP     9   SUBSTEP     1  COMPLETED.    CUM ITER =      9
       *** TIME =  0.900000E-01     TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.22       OSCILLATION LIMIT = 0.1922
       *** WARNING ***                         CP =       4.391   TIME= 14:14:04
       *DIM command.
       *** WARNING ***                         CP =       4.516   TIME= 14:14:04
       01055371  VERSION=WINDOWS x64   14:14:04  JAN 26, 2023 CP=      4.562
       *** LOAD STEP    10   SUBSTEP     1  COMPLETED.    CUM ITER =     10
       *** TIME =  0.100000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.81       OSCILLATION LIMIT = 0.1981
       *** WARNING ***                         CP =       4.875   TIME= 14:14:05
       *DIM command.
       *** WARNING ***                         CP =       4.938   TIME= 14:14:05
       01055371  VERSION=WINDOWS x64   14:14:05  JAN 26, 2023 CP=      5.000
       *** LOAD STEP    11   SUBSTEP     1  COMPLETED.    CUM ITER =     11
       *** TIME =  0.110000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.18       OSCILLATION LIMIT = 0.2018
       *** WARNING ***                         CP =       5.312   TIME= 14:14:05
       *DIM command.
       *** WARNING ***                         CP =       5.344   TIME= 14:14:05
       01055371  VERSION=WINDOWS x64   14:14:05  JAN 26, 2023 CP=      5.406
       *** LOAD STEP    12   SUBSTEP     1  COMPLETED.    CUM ITER =     12
       *** TIME =  0.120000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.36       OSCILLATION LIMIT = 0.2036
       *** WARNING ***                         CP =       5.734   TIME= 14:14:05
       *DIM command.
       *** WARNING ***                         CP =       5.766   TIME= 14:14:05
       01055371  VERSION=WINDOWS x64   14:14:06  JAN 26, 2023 CP=      5.812
       *** LOAD STEP    13   SUBSTEP     1  COMPLETED.    CUM ITER =     13
       *** TIME =  0.130000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.39       OSCILLATION LIMIT = 0.2039
       *** WARNING ***                         CP =       6.141   TIME= 14:14:06
       *DIM command.
       *** WARNING ***                         CP =       6.172   TIME= 14:14:06
       01055371  VERSION=WINDOWS x64   14:14:06  JAN 26, 2023 CP=      6.234
       *** LOAD STEP    14   SUBSTEP     1  COMPLETED.    CUM ITER =     14
       *** TIME =  0.140000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.32       OSCILLATION LIMIT = 0.2032
       *** WARNING ***                         CP =       6.547   TIME= 14:14:06
       *DIM command.
       *** WARNING ***                         CP =       6.625   TIME= 14:14:06
       01055371  VERSION=WINDOWS x64   14:14:06  JAN 26, 2023 CP=      6.719
       *** LOAD STEP    15   SUBSTEP     1  COMPLETED.    CUM ITER =     15
       *** TIME =  0.150000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.24       OSCILLATION LIMIT = 0.2024
       *** WARNING ***                         CP =       7.031   TIME= 14:14:07
       *DIM command.
       *** WARNING ***                         CP =       7.078   TIME= 14:14:07
       01055371  VERSION=WINDOWS x64   14:14:07  JAN 26, 2023 CP=      7.125
       *** LOAD STEP    16   SUBSTEP     1  COMPLETED.    CUM ITER =     16
       *** TIME =  0.160000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.20       OSCILLATION LIMIT = 0.2020
       *** WARNING ***                         CP =       7.438   TIME= 14:14:07
       *DIM command.
       *** WARNING ***                         CP =       7.469   TIME= 14:14:07
       01055371  VERSION=WINDOWS x64   14:14:07  JAN 26, 2023 CP=      7.516
       *** LOAD STEP    17   SUBSTEP     1  COMPLETED.    CUM ITER =     17
       *** TIME =  0.170000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.23       OSCILLATION LIMIT = 0.2023
       *** WARNING ***                         CP =       7.844   TIME= 14:14:08
       *DIM command.
       *** WARNING ***                         CP =       7.922   TIME= 14:14:08
       01055371  VERSION=WINDOWS x64   14:14:08  JAN 26, 2023 CP=      8.031
       *** LOAD STEP    18   SUBSTEP     1  COMPLETED.    CUM ITER =     18
       *** TIME =  0.180000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.34       OSCILLATION LIMIT = 0.2034
       *** WARNING ***                         CP =       8.359   TIME= 14:14:08
       *DIM command.
       *** WARNING ***                         CP =       8.453   TIME= 14:14:08
       01055371  VERSION=WINDOWS x64   14:14:08  JAN 26, 2023 CP=      8.562
       *** LOAD STEP    19   SUBSTEP     1  COMPLETED.    CUM ITER =     19
       *** TIME =  0.190000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.49       OSCILLATION LIMIT = 0.2049
       *** WARNING ***                         CP =       8.906   TIME= 14:14:08
       *DIM command.
       *** WARNING ***                         CP =       8.969   TIME= 14:14:09
       01055371  VERSION=WINDOWS x64   14:14:09  JAN 26, 2023 CP=      9.047
       *** LOAD STEP    20   SUBSTEP     1  COMPLETED.    CUM ITER =     20
       *** TIME =  0.200000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.64       OSCILLATION LIMIT = 0.2064
       *** WARNING ***                         CP =       9.359   TIME= 14:14:09
       *DIM command.
       *** WARNING ***                         CP =       9.438   TIME= 14:14:09
       01055371  VERSION=WINDOWS x64   14:14:09  JAN 26, 2023 CP=      9.500
       *** LOAD STEP    21   SUBSTEP     1  COMPLETED.    CUM ITER =     21
       *** TIME =  0.210000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.74       OSCILLATION LIMIT = 0.2074
       *** WARNING ***                         CP =       9.844   TIME= 14:14:09
       *DIM command.
       *** WARNING ***                         CP =       9.906   TIME= 14:14:09
       01055371  VERSION=WINDOWS x64   14:14:10  JAN 26, 2023 CP=      9.984
       *** LOAD STEP    22   SUBSTEP     1  COMPLETED.    CUM ITER =     22
       *** TIME =  0.220000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.77       OSCILLATION LIMIT = 0.2077
       *** WARNING ***                         CP =      10.312   TIME= 14:14:10
       *DIM command.
       *** WARNING ***                         CP =      10.391   TIME= 14:14:10
       01055371  VERSION=WINDOWS x64   14:14:10  JAN 26, 2023 CP=     10.453
       *** LOAD STEP    23   SUBSTEP     1  COMPLETED.    CUM ITER =     23
       *** TIME =  0.230000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.71       OSCILLATION LIMIT = 0.2071
       *** WARNING ***                         CP =      10.797   TIME= 14:14:10
       *DIM command.
       *** WARNING ***                         CP =      10.859   TIME= 14:14:10
       01055371  VERSION=WINDOWS x64   14:14:10  JAN 26, 2023 CP=     10.922
       *** LOAD STEP    24   SUBSTEP     1  COMPLETED.    CUM ITER =     24
       *** TIME =  0.240000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.59       OSCILLATION LIMIT = 0.2059
       *** WARNING ***                         CP =      11.250   TIME= 14:14:11
       *DIM command.
       *** WARNING ***                         CP =      11.297   TIME= 14:14:11
       01055371  VERSION=WINDOWS x64   14:14:11  JAN 26, 2023 CP=     11.375
       *** LOAD STEP    25   SUBSTEP     1  COMPLETED.    CUM ITER =     25
       *** TIME =  0.250000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.43       OSCILLATION LIMIT = 0.2043
       *** WARNING ***                         CP =      11.703   TIME= 14:14:11
       *DIM command.
       *** WARNING ***                         CP =      11.750   TIME= 14:14:11
       01055371  VERSION=WINDOWS x64   14:14:11  JAN 26, 2023 CP=     11.859
       *** LOAD STEP    26   SUBSTEP     1  COMPLETED.    CUM ITER =     26
       *** TIME =  0.260000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.28       OSCILLATION LIMIT = 0.2028
       *** WARNING ***                         CP =      12.156   TIME= 14:14:12
       *DIM command.
       *** WARNING ***                         CP =      12.266   TIME= 14:14:12
       01055371  VERSION=WINDOWS x64   14:14:12  JAN 26, 2023 CP=     12.328
       *** LOAD STEP    27   SUBSTEP     1  COMPLETED.    CUM ITER =     27
       *** TIME =  0.270000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.15       OSCILLATION LIMIT = 0.2015
       *** WARNING ***                         CP =      12.672   TIME= 14:14:12
       *DIM command.
       *** WARNING ***                         CP =      12.750   TIME= 14:14:12
       01055371  VERSION=WINDOWS x64   14:14:12  JAN 26, 2023 CP=     12.812
       *** LOAD STEP    28   SUBSTEP     1  COMPLETED.    CUM ITER =     28
       *** TIME =  0.280000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.07       OSCILLATION LIMIT = 0.2007
       *** WARNING ***                         CP =      13.109   TIME= 14:14:13
       *DIM command.
       *** WARNING ***                         CP =      13.188   TIME= 14:14:13
       01055371  VERSION=WINDOWS x64   14:14:13  JAN 26, 2023 CP=     13.250
       *** LOAD STEP    29   SUBSTEP     1  COMPLETED.    CUM ITER =     29
       *** TIME =  0.290000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.03       OSCILLATION LIMIT = 0.2003
       *** WARNING ***                         CP =      13.547   TIME= 14:14:13
       *DIM command.
       *** WARNING ***                         CP =      13.594   TIME= 14:14:13
       01055371  VERSION=WINDOWS x64   14:14:13  JAN 26, 2023 CP=     13.656
       *** LOAD STEP    30   SUBSTEP     1  COMPLETED.    CUM ITER =     30
       *** TIME =  0.300000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      14.000   TIME= 14:14:14
       *DIM command.
       *** WARNING ***                         CP =      14.109   TIME= 14:14:14
       01055371  VERSION=WINDOWS x64   14:14:14  JAN 26, 2023 CP=     14.188
       *** LOAD STEP    31   SUBSTEP     1  COMPLETED.    CUM ITER =     31
       *** TIME =  0.310000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.05       OSCILLATION LIMIT = 0.2005
       *** WARNING ***                         CP =      14.516   TIME= 14:14:14
       *DIM command.
       *** WARNING ***                         CP =      14.625   TIME= 14:14:14
       01055371  VERSION=WINDOWS x64   14:14:14  JAN 26, 2023 CP=     14.688
       *** LOAD STEP    32   SUBSTEP     1  COMPLETED.    CUM ITER =     32
       *** TIME =  0.320000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.06       OSCILLATION LIMIT = 0.2006
       *** WARNING ***                         CP =      14.984   TIME= 14:14:15
       *DIM command.
       *** WARNING ***                         CP =      15.062   TIME= 14:14:15
       01055371  VERSION=WINDOWS x64   14:14:15  JAN 26, 2023 CP=     15.125
       *** LOAD STEP    33   SUBSTEP     1  COMPLETED.    CUM ITER =     33
       *** TIME =  0.330000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      15.469   TIME= 14:14:15
       *DIM command.
       *** WARNING ***                         CP =      15.500   TIME= 14:14:15
       01055371  VERSION=WINDOWS x64   14:14:15  JAN 26, 2023 CP=     15.578
       *** LOAD STEP    34   SUBSTEP     1  COMPLETED.    CUM ITER =     34
       *** TIME =  0.340000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  20.00       OSCILLATION LIMIT = 0.2000
       *** WARNING ***                         CP =      15.906   TIME= 14:14:15
       *DIM command.
       *** WARNING ***                         CP =      16.000   TIME= 14:14:15
       01055371  VERSION=WINDOWS x64   14:14:16  JAN 26, 2023 CP=     16.062
       *** LOAD STEP    35   SUBSTEP     1  COMPLETED.    CUM ITER =     35
       *** TIME =  0.350000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.90       OSCILLATION LIMIT = 0.1990
       *** WARNING ***                         CP =      16.406   TIME= 14:14:16
       *DIM command.
       *** WARNING ***                         CP =      16.438   TIME= 14:14:16
       01055371  VERSION=WINDOWS x64   14:14:16  JAN 26, 2023 CP=     16.500
       *** LOAD STEP    36   SUBSTEP     1  COMPLETED.    CUM ITER =     36
       *** TIME =  0.360000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.77       OSCILLATION LIMIT = 0.1977
       *** WARNING ***                         CP =      16.844   TIME= 14:14:16
       *DIM command.
       *** WARNING ***                         CP =      16.891   TIME= 14:14:16
       01055371  VERSION=WINDOWS x64   14:14:16  JAN 26, 2023 CP=     16.953
       *** LOAD STEP    37   SUBSTEP     1  COMPLETED.    CUM ITER =     37
       *** TIME =  0.370000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.63       OSCILLATION LIMIT = 0.1963
       *** WARNING ***                         CP =      17.281   TIME= 14:14:17
       *DIM command.
       *** WARNING ***                         CP =      17.328   TIME= 14:14:17
       01055371  VERSION=WINDOWS x64   14:14:17  JAN 26, 2023 CP=     17.391
       *** LOAD STEP    38   SUBSTEP     1  COMPLETED.    CUM ITER =     38
       *** TIME =  0.380000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.50       OSCILLATION LIMIT = 0.1950
       *** WARNING ***                         CP =      17.734   TIME= 14:14:17
       *DIM command.
       *** WARNING ***                         CP =      17.797   TIME= 14:14:17
       01055371  VERSION=WINDOWS x64   14:14:17  JAN 26, 2023 CP=     17.875
       *** LOAD STEP    39   SUBSTEP     1  COMPLETED.    CUM ITER =     39
       *** TIME =  0.390000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.42       OSCILLATION LIMIT = 0.1942
       *** WARNING ***                         CP =      18.203   TIME= 14:14:18
       *DIM command.
       *** WARNING ***                         CP =      18.281   TIME= 14:14:18
       01055371  VERSION=WINDOWS x64   14:14:18  JAN 26, 2023 CP=     18.344
       *** LOAD STEP    40   SUBSTEP     1  COMPLETED.    CUM ITER =     40
       *** TIME =  0.400000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.38       OSCILLATION LIMIT = 0.1938
       *** WARNING ***                         CP =      18.672   TIME= 14:14:18
       *DIM command.
       *** WARNING ***                         CP =      18.781   TIME= 14:14:18
       01055371  VERSION=WINDOWS x64   14:14:18  JAN 26, 2023 CP=     18.844
       *** LOAD STEP    41   SUBSTEP     1  COMPLETED.    CUM ITER =     41
       *** TIME =  0.410000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      19.188   TIME= 14:14:19
       *DIM command.
       *** WARNING ***                         CP =      19.250   TIME= 14:14:19
       01055371  VERSION=WINDOWS x64   14:14:19  JAN 26, 2023 CP=     19.312
       *** LOAD STEP    42   SUBSTEP     1  COMPLETED.    CUM ITER =     42
       *** TIME =  0.420000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.40       OSCILLATION LIMIT = 0.1940
       *** WARNING ***                         CP =      19.641   TIME= 14:14:19
       *DIM command.
       *** WARNING ***                         CP =      19.719   TIME= 14:14:19
       01055371  VERSION=WINDOWS x64   14:14:19  JAN 26, 2023 CP=     19.781
       *** LOAD STEP    43   SUBSTEP     1  COMPLETED.    CUM ITER =     43
       *** TIME =  0.430000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      20.125   TIME= 14:14:19
       *DIM command.
       *** WARNING ***                         CP =      20.188   TIME= 14:14:20
       01055371  VERSION=WINDOWS x64   14:14:20  JAN 26, 2023 CP=     20.266
       *** LOAD STEP    44   SUBSTEP     1  COMPLETED.    CUM ITER =     44
       *** TIME =  0.440000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      20.594   TIME= 14:14:20
       *DIM command.
       *** WARNING ***                         CP =      20.672   TIME= 14:14:20
       01055371  VERSION=WINDOWS x64   14:14:20  JAN 26, 2023 CP=     20.781
       *** LOAD STEP    45   SUBSTEP     1  COMPLETED.    CUM ITER =     45
       *** TIME =  0.450000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      21.109   TIME= 14:14:20
       *DIM command.
       *** WARNING ***                         CP =      21.188   TIME= 14:14:20
       01055371  VERSION=WINDOWS x64   14:14:21  JAN 26, 2023 CP=     21.250
       *** LOAD STEP    46   SUBSTEP     1  COMPLETED.    CUM ITER =     46
       *** TIME =  0.460000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.31       OSCILLATION LIMIT = 0.1931
       *** WARNING ***                         CP =      21.594   TIME= 14:14:21
       *DIM command.
       *** WARNING ***                         CP =      21.672   TIME= 14:14:21
       01055371  VERSION=WINDOWS x64   14:14:21  JAN 26, 2023 CP=     21.750
       *** LOAD STEP    47   SUBSTEP     1  COMPLETED.    CUM ITER =     47
       *** TIME =  0.470000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.23       OSCILLATION LIMIT = 0.1923
       *** WARNING ***                         CP =      22.078   TIME= 14:14:21
       *DIM command.
       *** WARNING ***                         CP =      22.156   TIME= 14:14:21
       01055371  VERSION=WINDOWS x64   14:14:21  JAN 26, 2023 CP=     22.219
       *** LOAD STEP    48   SUBSTEP     1  COMPLETED.    CUM ITER =     48
       *** TIME =  0.480000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.14       OSCILLATION LIMIT = 0.1914
       *** WARNING ***                         CP =      22.531   TIME= 14:14:22
       *DIM command.
       *** WARNING ***                         CP =      22.594   TIME= 14:14:22
       01055371  VERSION=WINDOWS x64   14:14:22  JAN 26, 2023 CP=     22.656
       *** LOAD STEP    49   SUBSTEP     1  COMPLETED.    CUM ITER =     49
       *** TIME =  0.490000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.06       OSCILLATION LIMIT = 0.1906
       *** WARNING ***                         CP =      22.984   TIME= 14:14:22
       *DIM command.
       *** WARNING ***                         CP =      23.031   TIME= 14:14:22
       01055371  VERSION=WINDOWS x64   14:14:22  JAN 26, 2023 CP=     23.109
       *** LOAD STEP    50   SUBSTEP     1  COMPLETED.    CUM ITER =     50
       *** TIME =  0.500000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  19.01       OSCILLATION LIMIT = 0.1901
       *** WARNING ***                         CP =      23.438   TIME= 14:14:23
       *DIM command.
       *** WARNING ***                         CP =      23.484   TIME= 14:14:23
       01055371  VERSION=WINDOWS x64   14:14:23  JAN 26, 2023 CP=     23.547
       *** LOAD STEP    51   SUBSTEP     1  COMPLETED.    CUM ITER =     51
       *** TIME =  0.510000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.97       OSCILLATION LIMIT = 0.1897
       *** WARNING ***                         CP =      23.859   TIME= 14:14:23
       *DIM command.
       *** WARNING ***                         CP =      23.906   TIME= 14:14:23
       01055371  VERSION=WINDOWS x64   14:14:23  JAN 26, 2023 CP=     24.016
       *** LOAD STEP    52   SUBSTEP     1  COMPLETED.    CUM ITER =     52
       *** TIME =  0.520000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.95       OSCILLATION LIMIT = 0.1895
       *** WARNING ***                         CP =      24.344   TIME= 14:14:24
       *DIM command.
       *** WARNING ***                         CP =      24.438   TIME= 14:14:24
       01055371  VERSION=WINDOWS x64   14:14:24  JAN 26, 2023 CP=     24.516
       *** LOAD STEP    53   SUBSTEP     1  COMPLETED.    CUM ITER =     53
       *** TIME =  0.530000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.93       OSCILLATION LIMIT = 0.1893
       *** WARNING ***                         CP =      24.844   TIME= 14:14:24
       *DIM command.
       *** WARNING ***                         CP =      24.906   TIME= 14:14:24
       01055371  VERSION=WINDOWS x64   14:14:24  JAN 26, 2023 CP=     25.016
       *** LOAD STEP    54   SUBSTEP     1  COMPLETED.    CUM ITER =     54
       *** TIME =  0.540000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.89       OSCILLATION LIMIT = 0.1889
       *** WARNING ***                         CP =      25.328   TIME= 14:14:25
       *DIM command.
       *** WARNING ***                         CP =      25.391   TIME= 14:14:25
       01055371  VERSION=WINDOWS x64   14:14:25  JAN 26, 2023 CP=     25.453
       *** LOAD STEP    55   SUBSTEP     1  COMPLETED.    CUM ITER =     55
       *** TIME =  0.550000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      25.781   TIME= 14:14:25
       *DIM command.
       *** WARNING ***                         CP =      25.859   TIME= 14:14:25
       01055371  VERSION=WINDOWS x64   14:14:25  JAN 26, 2023 CP=     25.938
       *** LOAD STEP    56   SUBSTEP     1  COMPLETED.    CUM ITER =     56
       *** TIME =  0.560000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.78       OSCILLATION LIMIT = 0.1878
       *** WARNING ***                         CP =      26.266   TIME= 14:14:25
       *DIM command.
       *** WARNING ***                         CP =      26.328   TIME= 14:14:25
       01055371  VERSION=WINDOWS x64   14:14:26  JAN 26, 2023 CP=     26.391
       *** LOAD STEP    57   SUBSTEP     1  COMPLETED.    CUM ITER =     57
       *** TIME =  0.570000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.71       OSCILLATION LIMIT = 0.1871
       *** WARNING ***                         CP =      26.719   TIME= 14:14:26
       *DIM command.
       *** WARNING ***                         CP =      26.781   TIME= 14:14:26
       01055371  VERSION=WINDOWS x64   14:14:26  JAN 26, 2023 CP=     26.891
       *** LOAD STEP    58   SUBSTEP     1  COMPLETED.    CUM ITER =     58
       *** TIME =  0.580000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.66       OSCILLATION LIMIT = 0.1866
       *** WARNING ***                         CP =      27.234   TIME= 14:14:26
       *DIM command.
       *** WARNING ***                         CP =      27.312   TIME= 14:14:26
       01055371  VERSION=WINDOWS x64   14:14:26  JAN 26, 2023 CP=     27.391
       *** LOAD STEP    59   SUBSTEP     1  COMPLETED.    CUM ITER =     59
       *** TIME =  0.590000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.62       OSCILLATION LIMIT = 0.1862
       *** WARNING ***                         CP =      27.719   TIME= 14:14:27
       *DIM command.
       *** WARNING ***                         CP =      27.781   TIME= 14:14:27
       01055371  VERSION=WINDOWS x64   14:14:27  JAN 26, 2023 CP=     27.844
       *** LOAD STEP    60   SUBSTEP     1  COMPLETED.    CUM ITER =     60
       *** TIME =  0.600000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.61       OSCILLATION LIMIT = 0.1861
       *** WARNING ***                         CP =      28.172   TIME= 14:14:27
       *DIM command.
       *** WARNING ***                         CP =      28.219   TIME= 14:14:27
       01055371  VERSION=WINDOWS x64   14:14:27  JAN 26, 2023 CP=     28.297
       *** LOAD STEP    61   SUBSTEP     1  COMPLETED.    CUM ITER =     61
       *** TIME =  0.610000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      28.625   TIME= 14:14:28
       *DIM command.
       *** WARNING ***                         CP =      28.750   TIME= 14:14:28
       01055371  VERSION=WINDOWS x64   14:14:28  JAN 26, 2023 CP=     28.812
       *** LOAD STEP    62   SUBSTEP     1  COMPLETED.    CUM ITER =     62
       *** TIME =  0.620000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      29.141   TIME= 14:14:28
       *DIM command.
       *** WARNING ***                         CP =      29.188   TIME= 14:14:28
       01055371  VERSION=WINDOWS x64   14:14:28  JAN 26, 2023 CP=     29.250
       *** LOAD STEP    63   SUBSTEP     1  COMPLETED.    CUM ITER =     63
       *** TIME =  0.630000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.65       OSCILLATION LIMIT = 0.1865
       *** WARNING ***                         CP =      29.594   TIME= 14:14:29
       *DIM command.
       *** WARNING ***                         CP =      29.672   TIME= 14:14:29
       01055371  VERSION=WINDOWS x64   14:14:29  JAN 26, 2023 CP=     29.750
       *** LOAD STEP    64   SUBSTEP     1  COMPLETED.    CUM ITER =     64
       *** TIME =  0.640000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.67       OSCILLATION LIMIT = 0.1867
       *** WARNING ***                         CP =      30.078   TIME= 14:14:29
       *DIM command.
       *** WARNING ***                         CP =      30.125   TIME= 14:14:29
       01055371  VERSION=WINDOWS x64   14:14:29  JAN 26, 2023 CP=     30.234
       *** LOAD STEP    65   SUBSTEP     1  COMPLETED.    CUM ITER =     65
       *** TIME =  0.650000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.69       OSCILLATION LIMIT = 0.1869
       *** WARNING ***                         CP =      30.531   TIME= 14:14:30
       *DIM command.
       *** WARNING ***                         CP =      30.609   TIME= 14:14:30
       01055371  VERSION=WINDOWS x64   14:14:30  JAN 26, 2023 CP=     30.672
       *** LOAD STEP    66   SUBSTEP     1  COMPLETED.    CUM ITER =     66
       *** TIME =  0.660000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.70       OSCILLATION LIMIT = 0.1870
       *** WARNING ***                         CP =      31.016   TIME= 14:14:30
       *DIM command.
       *** WARNING ***                         CP =      31.078   TIME= 14:14:30
       01055371  VERSION=WINDOWS x64   14:14:30  JAN 26, 2023 CP=     31.156
       *** LOAD STEP    67   SUBSTEP     1  COMPLETED.    CUM ITER =     67
       *** TIME =  0.670000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      31.484   TIME= 14:14:31
       *DIM command.
       *** WARNING ***                         CP =      31.609   TIME= 14:14:31
       01055371  VERSION=WINDOWS x64   14:14:31  JAN 26, 2023 CP=     31.672
       *** LOAD STEP    68   SUBSTEP     1  COMPLETED.    CUM ITER =     68
       *** TIME =  0.680000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      32.016   TIME= 14:14:31
       *DIM command.
       *** WARNING ***                         CP =      32.078   TIME= 14:14:31
       01055371  VERSION=WINDOWS x64   14:14:31  JAN 26, 2023 CP=     32.141
       *** LOAD STEP    69   SUBSTEP     1  COMPLETED.    CUM ITER =     69
       *** TIME =  0.690000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.63       OSCILLATION LIMIT = 0.1863
       *** WARNING ***                         CP =      32.469   TIME= 14:14:31
       *DIM command.
       *** WARNING ***                         CP =      32.516   TIME= 14:14:32
       01055371  VERSION=WINDOWS x64   14:14:32  JAN 26, 2023 CP=     32.594
       *** LOAD STEP    70   SUBSTEP     1  COMPLETED.    CUM ITER =     70
       *** TIME =  0.700000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.56       OSCILLATION LIMIT = 0.1856
       *** WARNING ***                         CP =      32.922   TIME= 14:14:32
       *DIM command.
       *** WARNING ***                         CP =      33.000   TIME= 14:14:32
       01055371  VERSION=WINDOWS x64   14:14:32  JAN 26, 2023 CP=     33.062
       *** LOAD STEP    71   SUBSTEP     1  COMPLETED.    CUM ITER =     71
       *** TIME =  0.710000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.48       OSCILLATION LIMIT = 0.1848
       *** WARNING ***                         CP =      33.406   TIME= 14:14:32
       *DIM command.
       *** WARNING ***                         CP =      33.438   TIME= 14:14:32
       01055371  VERSION=WINDOWS x64   14:14:33  JAN 26, 2023 CP=     33.516
       *** LOAD STEP    72   SUBSTEP     1  COMPLETED.    CUM ITER =     72
       *** TIME =  0.720000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.40       OSCILLATION LIMIT = 0.1840
       *** WARNING ***                         CP =      33.844   TIME= 14:14:33
       *DIM command.
       *** WARNING ***                         CP =      33.922   TIME= 14:14:33
       01055371  VERSION=WINDOWS x64   14:14:33  JAN 26, 2023 CP=     33.984
       *** LOAD STEP    73   SUBSTEP     1  COMPLETED.    CUM ITER =     73
       *** TIME =  0.730000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.32       OSCILLATION LIMIT = 0.1832
       *** WARNING ***                         CP =      34.312   TIME= 14:14:33
       *DIM command.
       *** WARNING ***                         CP =      34.344   TIME= 14:14:33
       01055371  VERSION=WINDOWS x64   14:14:33  JAN 26, 2023 CP=     34.406
       *** LOAD STEP    74   SUBSTEP     1  COMPLETED.    CUM ITER =     74
       *** TIME =  0.740000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.28       OSCILLATION LIMIT = 0.1828
       *** WARNING ***                         CP =      34.750   TIME= 14:14:34
       *DIM command.
       *** WARNING ***                         CP =      34.781   TIME= 14:14:34
       01055371  VERSION=WINDOWS x64   14:14:34  JAN 26, 2023 CP=     34.859
       *** LOAD STEP    75   SUBSTEP     1  COMPLETED.    CUM ITER =     75
       *** TIME =  0.750000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.27       OSCILLATION LIMIT = 0.1827
       *** WARNING ***                         CP =      35.188   TIME= 14:14:34
       *DIM command.
       *** WARNING ***                         CP =      35.266   TIME= 14:14:34
       01055371  VERSION=WINDOWS x64   14:14:34  JAN 26, 2023 CP=     35.344
       *** LOAD STEP    76   SUBSTEP     1  COMPLETED.    CUM ITER =     76
       *** TIME =  0.760000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      35.656   TIME= 14:14:35
       *DIM command.
       *** WARNING ***                         CP =      35.750   TIME= 14:14:35
       01055371  VERSION=WINDOWS x64   14:14:35  JAN 26, 2023 CP=     35.812
       *** LOAD STEP    77   SUBSTEP     1  COMPLETED.    CUM ITER =     77
       *** TIME =  0.770000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.41       OSCILLATION LIMIT = 0.1841
       *** WARNING ***                         CP =      36.156   TIME= 14:14:35
       *DIM command.
       *** WARNING ***                         CP =      36.203   TIME= 14:14:35
       01055371  VERSION=WINDOWS x64   14:14:35  JAN 26, 2023 CP=     36.281
       *** LOAD STEP    78   SUBSTEP     1  COMPLETED.    CUM ITER =     78
       *** TIME =  0.780000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.52       OSCILLATION LIMIT = 0.1852
       *** WARNING ***                         CP =      36.609   TIME= 14:14:36
       *DIM command.
       *** WARNING ***                         CP =      36.672   TIME= 14:14:36
       01055371  VERSION=WINDOWS x64   14:14:36  JAN 26, 2023 CP=     36.781
       *** LOAD STEP    79   SUBSTEP     1  COMPLETED.    CUM ITER =     79
       *** TIME =  0.790000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      37.094   TIME= 14:14:36
       *DIM command.
       *** WARNING ***                         CP =      37.188   TIME= 14:14:36
       01055371  VERSION=WINDOWS x64   14:14:36  JAN 26, 2023 CP=     37.250
       *** LOAD STEP    80   SUBSTEP     1  COMPLETED.    CUM ITER =     80
       *** TIME =  0.800000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      37.594   TIME= 14:14:37
       *DIM command.
       *** WARNING ***                         CP =      37.625   TIME= 14:14:37
       01055371  VERSION=WINDOWS x64   14:14:37  JAN 26, 2023 CP=     37.703
       *** LOAD STEP    81   SUBSTEP     1  COMPLETED.    CUM ITER =     81
       *** TIME =  0.810000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      38.031   TIME= 14:14:37
       *DIM command.
       *** WARNING ***                         CP =      38.125   TIME= 14:14:37
       01055371  VERSION=WINDOWS x64   14:14:37  JAN 26, 2023 CP=     38.188
       *** LOAD STEP    82   SUBSTEP     1  COMPLETED.    CUM ITER =     82
       *** TIME =  0.820000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      38.500   TIME= 14:14:37
       *DIM command.
       *** WARNING ***                         CP =      38.547   TIME= 14:14:37
       01055371  VERSION=WINDOWS x64   14:14:38  JAN 26, 2023 CP=     38.625
       *** LOAD STEP    83   SUBSTEP     1  COMPLETED.    CUM ITER =     83
       *** TIME =  0.830000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.54       OSCILLATION LIMIT = 0.1854
       *** WARNING ***                         CP =      38.953   TIME= 14:14:38
       *DIM command.
       *** WARNING ***                         CP =      39.047   TIME= 14:14:38
       01055371  VERSION=WINDOWS x64   14:14:38  JAN 26, 2023 CP=     39.109
       *** LOAD STEP    84   SUBSTEP     1  COMPLETED.    CUM ITER =     84
       *** TIME =  0.840000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.47       OSCILLATION LIMIT = 0.1847
       *** WARNING ***                         CP =      39.438   TIME= 14:14:38
       *DIM command.
       *** WARNING ***                         CP =      39.547   TIME= 14:14:38
       01055371  VERSION=WINDOWS x64   14:14:38  JAN 26, 2023 CP=     39.609
       *** LOAD STEP    85   SUBSTEP     1  COMPLETED.    CUM ITER =     85
       *** TIME =  0.850000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      39.953   TIME= 14:14:39
       *DIM command.
       *** WARNING ***                         CP =      40.016   TIME= 14:14:39
       01055371  VERSION=WINDOWS x64   14:14:39  JAN 26, 2023 CP=     40.094
       *** LOAD STEP    86   SUBSTEP     1  COMPLETED.    CUM ITER =     86
       *** TIME =  0.860000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.38       OSCILLATION LIMIT = 0.1838
       *** WARNING ***                         CP =      40.422   TIME= 14:14:39
       *DIM command.
       *** WARNING ***                         CP =      40.484   TIME= 14:14:39
       01055371  VERSION=WINDOWS x64   14:14:39  JAN 26, 2023 CP=     40.547
       *** LOAD STEP    87   SUBSTEP     1  COMPLETED.    CUM ITER =     87
       *** TIME =  0.870000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.36       OSCILLATION LIMIT = 0.1836
       *** WARNING ***                         CP =      40.859   TIME= 14:14:40
       *DIM command.
       *** WARNING ***                         CP =      40.953   TIME= 14:14:40
       01055371  VERSION=WINDOWS x64   14:14:40  JAN 26, 2023 CP=     41.047
       *** LOAD STEP    88   SUBSTEP     1  COMPLETED.    CUM ITER =     88
       *** TIME =  0.880000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.34       OSCILLATION LIMIT = 0.1834
       *** WARNING ***                         CP =      41.391   TIME= 14:14:40
       *DIM command.
       *** WARNING ***                         CP =      41.406   TIME= 14:14:40
       01055371  VERSION=WINDOWS x64   14:14:40  JAN 26, 2023 CP=     41.484
       *** LOAD STEP    89   SUBSTEP     1  COMPLETED.    CUM ITER =     89
       *** TIME =  0.890000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.31       OSCILLATION LIMIT = 0.1831
       *** WARNING ***                         CP =      41.812   TIME= 14:14:41
       *DIM command.
       *** WARNING ***                         CP =      41.906   TIME= 14:14:41
       01055371  VERSION=WINDOWS x64   14:14:41  JAN 26, 2023 CP=     42.016
       *** LOAD STEP    90   SUBSTEP     1  COMPLETED.    CUM ITER =     90
       *** TIME =  0.900000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      42.359   TIME= 14:14:41
       *DIM command.
       *** WARNING ***                         CP =      42.438   TIME= 14:14:41
       01055371  VERSION=WINDOWS x64   14:14:41  JAN 26, 2023 CP=     42.500
       *** LOAD STEP    91   SUBSTEP     1  COMPLETED.    CUM ITER =     91
       *** TIME =  0.910000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.21       OSCILLATION LIMIT = 0.1821
       *** WARNING ***                         CP =      42.844   TIME= 14:14:42
       *DIM command.
       *** WARNING ***                         CP =      42.938   TIME= 14:14:42
       01055371  VERSION=WINDOWS x64   14:14:42  JAN 26, 2023 CP=     43.000
       *** LOAD STEP    92   SUBSTEP     1  COMPLETED.    CUM ITER =     92
       *** TIME =  0.920000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.16       OSCILLATION LIMIT = 0.1816
       *** WARNING ***                         CP =      43.328   TIME= 14:14:42
       *DIM command.
       *** WARNING ***                         CP =      43.406   TIME= 14:14:42
       01055371  VERSION=WINDOWS x64   14:14:42  JAN 26, 2023 CP=     43.469
       *** LOAD STEP    93   SUBSTEP     1  COMPLETED.    CUM ITER =     93
       *** TIME =  0.930000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.13       OSCILLATION LIMIT = 0.1813
       *** WARNING ***                         CP =      43.812   TIME= 14:14:43
       *DIM command.
       *** WARNING ***                         CP =      43.891   TIME= 14:14:43
       01055371  VERSION=WINDOWS x64   14:14:43  JAN 26, 2023 CP=     44.000
       *** LOAD STEP    94   SUBSTEP     1  COMPLETED.    CUM ITER =     94
       *** TIME =  0.940000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      44.344   TIME= 14:14:43
       *DIM command.
       *** WARNING ***                         CP =      44.375   TIME= 14:14:43
       01055371  VERSION=WINDOWS x64   14:14:43  JAN 26, 2023 CP=     44.453
       *** LOAD STEP    95   SUBSTEP     1  COMPLETED.    CUM ITER =     95
       *** TIME =  0.950000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.17       OSCILLATION LIMIT = 0.1817
       *** WARNING ***                         CP =      44.781   TIME= 14:14:43
       *DIM command.
       *** WARNING ***                         CP =      44.844   TIME= 14:14:44
       01055371  VERSION=WINDOWS x64   14:14:44  JAN 26, 2023 CP=     44.906
       *** LOAD STEP    96   SUBSTEP     1  COMPLETED.    CUM ITER =     96
       *** TIME =  0.960000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.24       OSCILLATION LIMIT = 0.1824
       *** WARNING ***                         CP =      45.250   TIME= 14:14:44
       *DIM command.
       *** WARNING ***                         CP =      45.359   TIME= 14:14:44
       01055371  VERSION=WINDOWS x64   14:14:44  JAN 26, 2023 CP=     45.469
       *** LOAD STEP    97   SUBSTEP     1  COMPLETED.    CUM ITER =     97
       *** TIME =  0.970000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.30       OSCILLATION LIMIT = 0.1830
       *** WARNING ***                         CP =      45.812   TIME= 14:14:44
       *DIM command.
       *** WARNING ***                         CP =      45.844   TIME= 14:14:44
       01055371  VERSION=WINDOWS x64   14:14:44  JAN 26, 2023 CP=     45.922
       *** LOAD STEP    98   SUBSTEP     1  COMPLETED.    CUM ITER =     98
       *** TIME =  0.980000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.35       OSCILLATION LIMIT = 0.1835
       *** WARNING ***                         CP =      46.250   TIME= 14:14:45
       *DIM command.
       *** WARNING ***                         CP =      46.312   TIME= 14:14:45
       01055371  VERSION=WINDOWS x64   14:14:45  JAN 26, 2023 CP=     46.375
       *** LOAD STEP    99   SUBSTEP     1  COMPLETED.    CUM ITER =     99
       *** TIME =  0.990000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      46.703   TIME= 14:14:45
       *DIM command.
       *** WARNING ***                         CP =      46.781   TIME= 14:14:45
       01055371  VERSION=WINDOWS x64   14:14:45  JAN 26, 2023 CP=     46.844
       *** LOAD STEP   100   SUBSTEP     1  COMPLETED.    CUM ITER =    100
       *** TIME =   1.00000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      47.188   TIME= 14:14:46
       *DIM command.
       *** WARNING ***                         CP =      47.234   TIME= 14:14:46
       01055371  VERSION=WINDOWS x64   14:14:46  JAN 26, 2023 CP=     47.312
       *** LOAD STEP   101   SUBSTEP     1  COMPLETED.    CUM ITER =    101
       *** TIME =   1.01000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      47.641   TIME= 14:14:46
       *DIM command.
       *** WARNING ***                         CP =      47.703   TIME= 14:14:46
       01055371  VERSION=WINDOWS x64   14:14:46  JAN 26, 2023 CP=     47.812
       *** LOAD STEP   102   SUBSTEP     1  COMPLETED.    CUM ITER =    102
       *** TIME =   1.02000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      48.141   TIME= 14:14:47
       *DIM command.
       *** WARNING ***                         CP =      48.219   TIME= 14:14:47
       01055371  VERSION=WINDOWS x64   14:14:47  JAN 26, 2023 CP=     48.297
       *** LOAD STEP   103   SUBSTEP     1  COMPLETED.    CUM ITER =    103
       *** TIME =   1.03000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.25       OSCILLATION LIMIT = 0.1825
       *** WARNING ***                         CP =      48.625   TIME= 14:14:47
       *DIM command.
       *** WARNING ***                         CP =      48.719   TIME= 14:14:47
       01055371  VERSION=WINDOWS x64   14:14:47  JAN 26, 2023 CP=     48.781
       *** LOAD STEP   104   SUBSTEP     1  COMPLETED.    CUM ITER =    104
       *** TIME =   1.04000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.26       OSCILLATION LIMIT = 0.1826
       *** WARNING ***                         CP =      49.109   TIME= 14:14:48
       *DIM command.
       *** WARNING ***                         CP =      49.203   TIME= 14:14:48
       01055371  VERSION=WINDOWS x64   14:14:48  JAN 26, 2023 CP=     49.266
       *** LOAD STEP   105   SUBSTEP     1  COMPLETED.    CUM ITER =    105
       *** TIME =   1.05000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      49.609   TIME= 14:14:48
       *DIM command.
       *** WARNING ***                         CP =      49.641   TIME= 14:14:48
       01055371  VERSION=WINDOWS x64   14:14:48  JAN 26, 2023 CP=     49.719
       *** LOAD STEP   106   SUBSTEP     1  COMPLETED.    CUM ITER =    106
       *** TIME =   1.06000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      50.047   TIME= 14:14:49
       *DIM command.
       *** WARNING ***                         CP =      50.125   TIME= 14:14:49
       01055371  VERSION=WINDOWS x64   14:14:49  JAN 26, 2023 CP=     50.188
       *** LOAD STEP   107   SUBSTEP     1  COMPLETED.    CUM ITER =    107
       *** TIME =   1.07000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      50.516   TIME= 14:14:49
       *DIM command.
       *** WARNING ***                         CP =      50.594   TIME= 14:14:49
       01055371  VERSION=WINDOWS x64   14:14:49  JAN 26, 2023 CP=     50.672
       *** LOAD STEP   108   SUBSTEP     1  COMPLETED.    CUM ITER =    108
       *** TIME =   1.08000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      51.000   TIME= 14:14:49
       *DIM command.
       *** WARNING ***                         CP =      51.047   TIME= 14:14:49
       01055371  VERSION=WINDOWS x64   14:14:50  JAN 26, 2023 CP=     51.109
       *** LOAD STEP   109   SUBSTEP     1  COMPLETED.    CUM ITER =    109
       *** TIME =   1.09000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.45       OSCILLATION LIMIT = 0.1845
       *** WARNING ***                         CP =      51.438   TIME= 14:14:50
       *DIM command.
       *** WARNING ***                         CP =      51.484   TIME= 14:14:50
       01055371  VERSION=WINDOWS x64   14:14:50  JAN 26, 2023 CP=     51.594
       *** LOAD STEP   110   SUBSTEP     1  COMPLETED.    CUM ITER =    110
       *** TIME =   1.10000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.43       OSCILLATION LIMIT = 0.1843
       *** WARNING ***                         CP =      51.938   TIME= 14:14:50
       *DIM command.
       *** WARNING ***                         CP =      52.016   TIME= 14:14:50
       01055371  VERSION=WINDOWS x64   14:14:50  JAN 26, 2023 CP=     52.078
       *** LOAD STEP   111   SUBSTEP     1  COMPLETED.    CUM ITER =    111
       *** TIME =   1.11000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.39       OSCILLATION LIMIT = 0.1839
       *** WARNING ***                         CP =      52.422   TIME= 14:14:51
       *DIM command.
       *** WARNING ***                         CP =      52.469   TIME= 14:14:51
       01055371  VERSION=WINDOWS x64   14:14:51  JAN 26, 2023 CP=     52.531
       *** LOAD STEP   112   SUBSTEP     1  COMPLETED.    CUM ITER =    112
       *** TIME =   1.12000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.33       OSCILLATION LIMIT = 0.1833
       *** WARNING ***                         CP =      52.859   TIME= 14:14:51
       *DIM command.
       *** WARNING ***                         CP =      52.906   TIME= 14:14:51
       01055371  VERSION=WINDOWS x64   14:14:51  JAN 26, 2023 CP=     52.969
       *** LOAD STEP   113   SUBSTEP     1  COMPLETED.    CUM ITER =    113
       *** TIME =   1.13000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      53.312   TIME= 14:14:52
       *DIM command.
       *** WARNING ***                         CP =      53.344   TIME= 14:14:52
       01055371  VERSION=WINDOWS x64   14:14:52  JAN 26, 2023 CP=     53.422
       *** LOAD STEP   114   SUBSTEP     1  COMPLETED.    CUM ITER =    114
       *** TIME =   1.14000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.22       OSCILLATION LIMIT = 0.1822
       *** WARNING ***                         CP =      53.766   TIME= 14:14:52
       *DIM command.
       *** WARNING ***                         CP =      53.828   TIME= 14:14:52
       01055371  VERSION=WINDOWS x64   14:14:52  JAN 26, 2023 CP=     53.891
       *** LOAD STEP   115   SUBSTEP     1  COMPLETED.    CUM ITER =    115
       *** TIME =   1.15000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      54.234   TIME= 14:14:53
       *DIM command.
       *** WARNING ***                         CP =      54.281   TIME= 14:14:53
       01055371  VERSION=WINDOWS x64   14:14:53  JAN 26, 2023 CP=     54.344
       *** LOAD STEP   116   SUBSTEP     1  COMPLETED.    CUM ITER =    116
       *** TIME =   1.16000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.23       OSCILLATION LIMIT = 0.1823
       *** WARNING ***                         CP =      54.656   TIME= 14:14:53
       *DIM command.
       *** WARNING ***                         CP =      54.781   TIME= 14:14:53
       01055371  VERSION=WINDOWS x64   14:14:53  JAN 26, 2023 CP=     54.844
       *** LOAD STEP   117   SUBSTEP     1  COMPLETED.    CUM ITER =    117
       *** TIME =   1.17000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      55.188   TIME= 14:14:53
       *DIM command.
       *** WARNING ***                         CP =      55.250   TIME= 14:14:54
       01055371  VERSION=WINDOWS x64   14:14:54  JAN 26, 2023 CP=     55.328
       *** LOAD STEP   118   SUBSTEP     1  COMPLETED.    CUM ITER =    118
       *** TIME =   1.18000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      55.641   TIME= 14:14:54
       *DIM command.
       *** WARNING ***                         CP =      55.688   TIME= 14:14:54
       01055371  VERSION=WINDOWS x64   14:14:54  JAN 26, 2023 CP=     55.750
       *** LOAD STEP   119   SUBSTEP     1  COMPLETED.    CUM ITER =    119
       *** TIME =   1.19000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      56.094   TIME= 14:14:54
       *DIM command.
       *** WARNING ***                         CP =      56.141   TIME= 14:14:54
       01055371  VERSION=WINDOWS x64   14:14:55  JAN 26, 2023 CP=     56.219
       *** LOAD STEP   120   SUBSTEP     1  COMPLETED.    CUM ITER =    120
       *** TIME =   1.20000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      56.547   TIME= 14:14:55
       *DIM command.
       *** WARNING ***                         CP =      56.609   TIME= 14:14:55
       01055371  VERSION=WINDOWS x64   14:14:55  JAN 26, 2023 CP=     56.656
       *** LOAD STEP   121   SUBSTEP     1  COMPLETED.    CUM ITER =    121
       *** TIME =   1.21000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      56.969   TIME= 14:14:55
       *DIM command.
       *** WARNING ***                         CP =      57.062   TIME= 14:14:55
       01055371  VERSION=WINDOWS x64   14:14:55  JAN 26, 2023 CP=     57.125
       *** LOAD STEP   122   SUBSTEP     1  COMPLETED.    CUM ITER =    122
       *** TIME =   1.22000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      57.469   TIME= 14:14:56
       *DIM command.
       *** WARNING ***                         CP =      57.531   TIME= 14:14:56
       01055371  VERSION=WINDOWS x64   14:14:56  JAN 26, 2023 CP=     57.609
       *** LOAD STEP   123   SUBSTEP     1  COMPLETED.    CUM ITER =    123
       *** TIME =   1.23000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      57.938   TIME= 14:14:56
       *DIM command.
       *** WARNING ***                         CP =      58.016   TIME= 14:14:56
       01055371  VERSION=WINDOWS x64   14:14:56  JAN 26, 2023 CP=     58.078
       *** LOAD STEP   124   SUBSTEP     1  COMPLETED.    CUM ITER =    124
       *** TIME =   1.24000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      58.375   TIME= 14:14:57
       *DIM command.
       *** WARNING ***                         CP =      58.422   TIME= 14:14:57
       01055371  VERSION=WINDOWS x64   14:14:57  JAN 26, 2023 CP=     58.484
       *** LOAD STEP   125   SUBSTEP     1  COMPLETED.    CUM ITER =    125
       *** TIME =   1.25000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.19       OSCILLATION LIMIT = 0.1819
       *** WARNING ***                         CP =      58.828   TIME= 14:14:57
       *DIM command.
       *** WARNING ***                         CP =      58.875   TIME= 14:14:57
       Ansys Mechanical Enterprise Academic Student
       01055371  VERSION=WINDOWS x64   14:14:57  JAN 26, 2023 CP=     58.953
       *** LOAD STEP   126   SUBSTEP     1  COMPLETED.    CUM ITER =    126
       *** TIME =   1.26000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      59.281   TIME= 14:14:58
       *DIM command.
       *** WARNING ***                         CP =      59.375   TIME= 14:14:58
       01055371  VERSION=WINDOWS x64   14:14:58  JAN 26, 2023 CP=     59.438
       *** LOAD STEP   127   SUBSTEP     1  COMPLETED.    CUM ITER =    127
       *** TIME =   1.27000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.12       OSCILLATION LIMIT = 0.1812
       *** WARNING ***                         CP =      59.766   TIME= 14:14:58
       *DIM command.
       *** WARNING ***                         CP =      59.875   TIME= 14:14:58
       01055371  VERSION=WINDOWS x64   14:14:58  JAN 26, 2023 CP=     59.984
       *** LOAD STEP   128   SUBSTEP     1  COMPLETED.    CUM ITER =    128
       *** TIME =   1.28000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      60.328   TIME= 14:14:59
       *DIM command.
       *** WARNING ***                         CP =      60.359   TIME= 14:14:59
       01055371  VERSION=WINDOWS x64   14:14:59  JAN 26, 2023 CP=     60.438
       *** LOAD STEP   129   SUBSTEP     1  COMPLETED.    CUM ITER =    129
       *** TIME =   1.29000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      60.766   TIME= 14:14:59
       *DIM command.
       *** WARNING ***                         CP =      60.828   TIME= 14:14:59
       01055371  VERSION=WINDOWS x64   14:14:59  JAN 26, 2023 CP=     60.938
       *** LOAD STEP   130   SUBSTEP     1  COMPLETED.    CUM ITER =    130
       *** TIME =   1.30000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      61.281   TIME= 14:14:59
       *DIM command.
       *** WARNING ***                         CP =      61.344   TIME= 14:15:00
       01055371  VERSION=WINDOWS x64   14:15:00  JAN 26, 2023 CP=     61.406
       *** LOAD STEP   131   SUBSTEP     1  COMPLETED.    CUM ITER =    131
       *** TIME =   1.31000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      61.750   TIME= 14:15:00
       *DIM command.
       *** WARNING ***                         CP =      61.797   TIME= 14:15:00
       01055371  VERSION=WINDOWS x64   14:15:00  JAN 26, 2023 CP=     61.859
       *** LOAD STEP   132   SUBSTEP     1  COMPLETED.    CUM ITER =    132
       *** TIME =   1.32000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      62.172   TIME= 14:15:00
       *DIM command.
       *** WARNING ***                         CP =      62.250   TIME= 14:15:00
       01055371  VERSION=WINDOWS x64   14:15:01  JAN 26, 2023 CP=     62.312
       *** LOAD STEP   133   SUBSTEP     1  COMPLETED.    CUM ITER =    133
       *** TIME =   1.33000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      62.656   TIME= 14:15:01
       *DIM command.
       *** WARNING ***                         CP =      62.719   TIME= 14:15:01
       01055371  VERSION=WINDOWS x64   14:15:01  JAN 26, 2023 CP=     62.781
       *** LOAD STEP   134   SUBSTEP     1  COMPLETED.    CUM ITER =    134
       *** TIME =   1.34000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      63.125   TIME= 14:15:01
       *DIM command.
       *** WARNING ***                         CP =      63.219   TIME= 14:15:01
       01055371  VERSION=WINDOWS x64   14:15:01  JAN 26, 2023 CP=     63.328
       *** LOAD STEP   135   SUBSTEP     1  COMPLETED.    CUM ITER =    135
       *** TIME =   1.35000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      63.672   TIME= 14:15:02
       *DIM command.
       *** WARNING ***                         CP =      63.734   TIME= 14:15:02
       01055371  VERSION=WINDOWS x64   14:15:02  JAN 26, 2023 CP=     63.797
       *** LOAD STEP   136   SUBSTEP     1  COMPLETED.    CUM ITER =    136
       *** TIME =   1.36000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      64.094   TIME= 14:15:02
       *DIM command.
       *** WARNING ***                         CP =      64.250   TIME= 14:15:02
       01055371  VERSION=WINDOWS x64   14:15:02  JAN 26, 2023 CP=     64.359
       wbnew--Transient Thermal (A5)
       *** LOAD STEP   137   SUBSTEP     1  COMPLETED.    CUM ITER =    137
       *** TIME =   1.37000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      64.703   TIME= 14:15:03
       *DIM command.
       *** WARNING ***                         CP =      64.766   TIME= 14:15:03
       01055371  VERSION=WINDOWS x64   14:15:03  JAN 26, 2023 CP=     64.828
       *** LOAD STEP   138   SUBSTEP     1  COMPLETED.    CUM ITER =    138
       *** TIME =   1.38000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      65.172   TIME= 14:15:03
       *DIM command.
       *** WARNING ***                         CP =      65.234   TIME= 14:15:03
       01055371  VERSION=WINDOWS x64   14:15:03  JAN 26, 2023 CP=     65.312
       *** LOAD STEP   139   SUBSTEP     1  COMPLETED.    CUM ITER =    139
       *** TIME =   1.39000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      65.641   TIME= 14:15:04
       *DIM command.
       *** WARNING ***                         CP =      65.734   TIME= 14:15:04
       01055371  VERSION=WINDOWS x64   14:15:04  JAN 26, 2023 CP=     65.797
       *** LOAD STEP   140   SUBSTEP     1  COMPLETED.    CUM ITER =    140
       *** TIME =   1.40000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      66.141   TIME= 14:15:04
       *DIM command.
       *** WARNING ***                         CP =      66.172   TIME= 14:15:04
       *** MAPDL - ENGINEERING ANALYSIS SYSTEM  RELEASE 2023 R1          23.1     ***
       01055371  VERSION=WINDOWS x64   14:15:04  JAN 26, 2023 CP=     66.250
       *** LOAD STEP   141   SUBSTEP     1  COMPLETED.    CUM ITER =    141
       *** TIME =   1.41000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      66.578   TIME= 14:15:05
       *DIM command.
       *** WARNING ***                         CP =      66.641   TIME= 14:15:05
       01055371  VERSION=WINDOWS x64   14:15:05  JAN 26, 2023 CP=     66.703
       *** LOAD STEP   142   SUBSTEP     1  COMPLETED.    CUM ITER =    142
       *** TIME =   1.42000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      67.000   TIME= 14:15:05
       *DIM command.
       *** WARNING ***                         CP =      67.062   TIME= 14:15:05
       01055371  VERSION=WINDOWS x64   14:15:05  JAN 26, 2023 CP=     67.125
       *** LOAD STEP   143   SUBSTEP     1  COMPLETED.    CUM ITER =    143
       *** TIME =   1.43000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.18       OSCILLATION LIMIT = 0.1818
       *** WARNING ***                         CP =      67.469   TIME= 14:15:05
       *DIM command.
       *** WARNING ***                         CP =      67.500   TIME= 14:15:06
       01055371  VERSION=WINDOWS x64   14:15:06  JAN 26, 2023 CP=     67.578
       *** LOAD STEP   144   SUBSTEP     1  COMPLETED.    CUM ITER =    144
       *** TIME =   1.44000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.14       OSCILLATION LIMIT = 0.1814
       *** WARNING ***                         CP =      67.906   TIME= 14:15:06
       *DIM command.
       *** WARNING ***                         CP =      67.984   TIME= 14:15:06
       01055371  VERSION=WINDOWS x64   14:15:06  JAN 26, 2023 CP=     68.047
       *** LOAD STEP   145   SUBSTEP     1  COMPLETED.    CUM ITER =    145
       *** TIME =   1.45000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.11       OSCILLATION LIMIT = 0.1811
       *** WARNING ***                         CP =      68.391   TIME= 14:15:06
       *DIM command.
       *** WARNING ***                         CP =      68.453   TIME= 14:15:06
       01055371  VERSION=WINDOWS x64   14:15:07  JAN 26, 2023 CP=     68.516
       *** LOAD STEP   146   SUBSTEP     1  COMPLETED.    CUM ITER =    146
       *** TIME =   1.46000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      68.859   TIME= 14:15:07
       *DIM command.
       *** WARNING ***                         CP =      68.891   TIME= 14:15:07
       01055371  VERSION=WINDOWS x64   14:15:07  JAN 26, 2023 CP=     68.969
       *** LOAD STEP   147   SUBSTEP     1  COMPLETED.    CUM ITER =    147
       *** TIME =   1.47000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      69.281   TIME= 14:15:07
       *DIM command.
       *** WARNING ***                         CP =      69.344   TIME= 14:15:07
       01055371  VERSION=WINDOWS x64   14:15:07  JAN 26, 2023 CP=     69.406
       *** LOAD STEP   148   SUBSTEP     1  COMPLETED.    CUM ITER =    148
       *** TIME =   1.48000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      69.750   TIME= 14:15:08
       *DIM command.
       *** WARNING ***                         CP =      69.812   TIME= 14:15:08
       01055371  VERSION=WINDOWS x64   14:15:08  JAN 26, 2023 CP=     69.891
       *** LOAD STEP   149   SUBSTEP     1  COMPLETED.    CUM ITER =    149
       *** TIME =   1.49000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      70.219   TIME= 14:15:08
       *DIM command.
       *** WARNING ***                         CP =      70.266   TIME= 14:15:08
       01055371  VERSION=WINDOWS x64   14:15:08  JAN 26, 2023 CP=     70.328
       *** LOAD STEP   150   SUBSTEP     1  COMPLETED.    CUM ITER =    150
       *** TIME =   1.50000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.15       OSCILLATION LIMIT = 0.1815
       *** WARNING ***                         CP =      70.609   TIME= 14:15:09
       *DIM command.
       *** WARNING ***                         CP =      70.734   TIME= 14:15:09
       01055371  VERSION=WINDOWS x64   14:15:09  JAN 26, 2023 CP=     70.797
       *** LOAD STEP   151   SUBSTEP     1  COMPLETED.    CUM ITER =    151
       *** TIME =   1.51000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      71.141   TIME= 14:15:09
       *DIM command.
       *** WARNING ***                         CP =      71.203   TIME= 14:15:09
       01055371  VERSION=WINDOWS x64   14:15:09  JAN 26, 2023 CP=     71.281
       *** LOAD STEP   152   SUBSTEP     1  COMPLETED.    CUM ITER =    152
       *** TIME =   1.52000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.06       OSCILLATION LIMIT = 0.1806
       *** WARNING ***                         CP =      71.609   TIME= 14:15:10
       *DIM command.
       *** WARNING ***                         CP =      71.656   TIME= 14:15:10
       01055371  VERSION=WINDOWS x64   14:15:10  JAN 26, 2023 CP=     71.719
       *** LOAD STEP   153   SUBSTEP     1  COMPLETED.    CUM ITER =    153
       *** TIME =   1.53000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.01       OSCILLATION LIMIT = 0.1801
       *** WARNING ***                         CP =      72.062   TIME= 14:15:10
       *DIM command.
       *** WARNING ***                         CP =      72.125   TIME= 14:15:10
       01055371  VERSION=WINDOWS x64   14:15:10  JAN 26, 2023 CP=     72.203
       *** LOAD STEP   154   SUBSTEP     1  COMPLETED.    CUM ITER =    154
       *** TIME =   1.54000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  17.98       OSCILLATION LIMIT = 0.1798
       *** WARNING ***                         CP =      72.531   TIME= 14:15:11
       *DIM command.
       *** WARNING ***                         CP =      72.625   TIME= 14:15:11
       01055371  VERSION=WINDOWS x64   14:15:11  JAN 26, 2023 CP=     72.688
       *** LOAD STEP   155   SUBSTEP     1  COMPLETED.    CUM ITER =    155
       *** TIME =   1.55000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  17.99       OSCILLATION LIMIT = 0.1799
       *** WARNING ***                         CP =      73.016   TIME= 14:15:11
       *DIM command.
       *** WARNING ***                         CP =      73.156   TIME= 14:15:11
       01055371  VERSION=WINDOWS x64   14:15:11  JAN 26, 2023 CP=     73.266
       *** LOAD STEP   156   SUBSTEP     1  COMPLETED.    CUM ITER =    156
       *** TIME =   1.56000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.02       OSCILLATION LIMIT = 0.1802
       *** WARNING ***                         CP =      73.609   TIME= 14:15:11
       *DIM command.
       *** WARNING ***                         CP =      73.641   TIME= 14:15:12
       01055371  VERSION=WINDOWS x64   14:15:12  JAN 26, 2023 CP=     73.719
       *** LOAD STEP   157   SUBSTEP     1  COMPLETED.    CUM ITER =    157
       *** TIME =   1.57000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.07       OSCILLATION LIMIT = 0.1807
       *** WARNING ***                         CP =      74.031   TIME= 14:15:12
       *DIM command.
       *** WARNING ***                         CP =      74.078   TIME= 14:15:12
       01055371  VERSION=WINDOWS x64   14:15:12  JAN 26, 2023 CP=     74.141
       *** LOAD STEP   158   SUBSTEP     1  COMPLETED.    CUM ITER =    158
       *** TIME =   1.58000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.10       OSCILLATION LIMIT = 0.1810
       *** WARNING ***                         CP =      74.469   TIME= 14:15:12
       *DIM command.
       *** WARNING ***                         CP =      74.531   TIME= 14:15:12
       01055371  VERSION=WINDOWS x64   14:15:12  JAN 26, 2023 CP=     74.594
       *** LOAD STEP   159   SUBSTEP     1  COMPLETED.    CUM ITER =    159
       *** TIME =   1.59000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      74.938   TIME= 14:15:13
       *DIM command.
       *** WARNING ***                         CP =      74.969   TIME= 14:15:13
       01055371  VERSION=WINDOWS x64   14:15:13  JAN 26, 2023 CP=     75.047
       *** LOAD STEP   160   SUBSTEP     1  COMPLETED.    CUM ITER =    160
       *** TIME =   1.60000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      75.375   TIME= 14:15:13
       *DIM command.
       *** WARNING ***                         CP =      75.484   TIME= 14:15:13
       01055371  VERSION=WINDOWS x64   14:15:13  JAN 26, 2023 CP=     75.547
       *** LOAD STEP   161   SUBSTEP     1  COMPLETED.    CUM ITER =    161
       *** TIME =   1.61000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      75.922   TIME= 14:15:14
       *DIM command.
       *** WARNING ***                         CP =      76.031   TIME= 14:15:14
       01055371  VERSION=WINDOWS x64   14:15:14  JAN 26, 2023 CP=     76.109
       *** LOAD STEP   162   SUBSTEP     1  COMPLETED.    CUM ITER =    162
       *** TIME =   1.62000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  17.92       OSCILLATION LIMIT = 0.1792
       *** WARNING ***                         CP =      76.438   TIME= 14:15:14
       *DIM command.
       *** WARNING ***                         CP =      76.500   TIME= 14:15:14
       01055371  VERSION=WINDOWS x64   14:15:14  JAN 26, 2023 CP=     76.578
       *** LOAD STEP   163   SUBSTEP     1  COMPLETED.    CUM ITER =    163
       *** TIME =   1.63000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  17.88       OSCILLATION LIMIT = 0.1788
       *** WARNING ***                         CP =      76.906   TIME= 14:15:15
       *DIM command.
       *** WARNING ***                         CP =      77.031   TIME= 14:15:15
       01055371  VERSION=WINDOWS x64   14:15:15  JAN 26, 2023 CP=     77.094
       *** LOAD STEP   164   SUBSTEP     1  COMPLETED.    CUM ITER =    164
       *** TIME =   1.64000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      77.438   TIME= 14:15:15
       *DIM command.
       *** WARNING ***                         CP =      77.500   TIME= 14:15:15
       01055371  VERSION=WINDOWS x64   14:15:15  JAN 26, 2023 CP=     77.562
       *** LOAD STEP   165   SUBSTEP     1  COMPLETED.    CUM ITER =    165
       *** TIME =   1.65000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  17.93       OSCILLATION LIMIT = 0.1793
       *** WARNING ***                         CP =      77.906   TIME= 14:15:16
       *DIM command.
       *** WARNING ***                         CP =      77.969   TIME= 14:15:16
       01055371  VERSION=WINDOWS x64   14:15:16  JAN 26, 2023 CP=     78.031
       *** LOAD STEP   166   SUBSTEP     1  COMPLETED.    CUM ITER =    166
       *** TIME =   1.66000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      78.375   TIME= 14:15:16
       *DIM command.
       *** WARNING ***                         CP =      78.422   TIME= 14:15:16
       01055371  VERSION=WINDOWS x64   14:15:16  JAN 26, 2023 CP=     78.484
       *** LOAD STEP   167   SUBSTEP     1  COMPLETED.    CUM ITER =    167
       *** TIME =   1.67000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      78.797   TIME= 14:15:17
       *DIM command.
       *** WARNING ***                         CP =      78.844   TIME= 14:15:17
       01055371  VERSION=WINDOWS x64   14:15:17  JAN 26, 2023 CP=     78.906
       *** LOAD STEP   168   SUBSTEP     1  COMPLETED.    CUM ITER =    168
       *** TIME =   1.68000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      79.250   TIME= 14:15:17
       *DIM command.
       *** WARNING ***                         CP =      79.312   TIME= 14:15:17
       01055371  VERSION=WINDOWS x64   14:15:17  JAN 26, 2023 CP=     79.391
       *** LOAD STEP   169   SUBSTEP     1  COMPLETED.    CUM ITER =    169
       *** TIME =   1.69000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      79.719   TIME= 14:15:17
       *DIM command.
       *** WARNING ***                         CP =      79.781   TIME= 14:15:18
       01055371  VERSION=WINDOWS x64   14:15:18  JAN 26, 2023 CP=     79.844
       *** LOAD STEP   170   SUBSTEP     1  COMPLETED.    CUM ITER =    170
       *** TIME =   1.70000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      80.188   TIME= 14:15:18
       *DIM command.
       *** WARNING ***                         CP =      80.266   TIME= 14:15:18
       01055371  VERSION=WINDOWS x64   14:15:18  JAN 26, 2023 CP=     80.328
       *** LOAD STEP   171   SUBSTEP     1  COMPLETED.    CUM ITER =    171
       *** TIME =   1.71000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      80.672   TIME= 14:15:18
       *DIM command.
       *** WARNING ***                         CP =      80.766   TIME= 14:15:19
       01055371  VERSION=WINDOWS x64   14:15:19  JAN 26, 2023 CP=     80.844
       *** LOAD STEP   172   SUBSTEP     1  COMPLETED.    CUM ITER =    172
       *** TIME =   1.72000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.37       OSCILLATION LIMIT = 0.1837
       *** WARNING ***                         CP =      81.172   TIME= 14:15:19
       *DIM command.
       *** WARNING ***                         CP =      81.219   TIME= 14:15:19
       01055371  VERSION=WINDOWS x64   14:15:19  JAN 26, 2023 CP=     81.281
       *** LOAD STEP   173   SUBSTEP     1  COMPLETED.    CUM ITER =    173
       *** TIME =   1.73000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      81.625   TIME= 14:15:19
       *DIM command.
       *** WARNING ***                         CP =      81.688   TIME= 14:15:19
       01055371  VERSION=WINDOWS x64   14:15:19  JAN 26, 2023 CP=     81.766
       *** LOAD STEP   174   SUBSTEP     1  COMPLETED.    CUM ITER =    174
       *** TIME =   1.74000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      82.094   TIME= 14:15:20
       *DIM command.
       *** WARNING ***                         CP =      82.141   TIME= 14:15:20
       01055371  VERSION=WINDOWS x64   14:15:20  JAN 26, 2023 CP=     82.203
       *** LOAD STEP   175   SUBSTEP     1  COMPLETED.    CUM ITER =    175
       *** TIME =   1.75000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      82.531   TIME= 14:15:20
       *DIM command.
       *** WARNING ***                         CP =      82.562   TIME= 14:15:20
       01055371  VERSION=WINDOWS x64   14:15:20  JAN 26, 2023 CP=     82.672
       *** LOAD STEP   176   SUBSTEP     1  COMPLETED.    CUM ITER =    176
       *** TIME =   1.76000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      83.016   TIME= 14:15:21
       *DIM command.
       *** WARNING ***                         CP =      83.062   TIME= 14:15:21
       01055371  VERSION=WINDOWS x64   14:15:21  JAN 26, 2023 CP=     83.141
       *** LOAD STEP   177   SUBSTEP     1  COMPLETED.    CUM ITER =    177
       *** TIME =   1.77000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      83.469   TIME= 14:15:21
       *DIM command.
       *** WARNING ***                         CP =      83.547   TIME= 14:15:21
       01055371  VERSION=WINDOWS x64   14:15:21  JAN 26, 2023 CP=     83.609
       *** LOAD STEP   178   SUBSTEP     1  COMPLETED.    CUM ITER =    178
       *** TIME =   1.78000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      83.938   TIME= 14:15:22
       *DIM command.
       *****  MAPDL SOLVE    COMMAND  *****
       *** WARNING ***                         CP =      84.031   TIME= 14:15:22
       01055371  VERSION=WINDOWS x64   14:15:22  JAN 26, 2023 CP=     84.094
       *** LOAD STEP   179   SUBSTEP     1  COMPLETED.    CUM ITER =    179
       *** TIME =   1.79000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      84.438   TIME= 14:15:22
       *DIM command.
       *** WARNING ***                         CP =      84.531   TIME= 14:15:22
       01055371  VERSION=WINDOWS x64   14:15:22  JAN 26, 2023 CP=     84.594
       *** LOAD STEP   180   SUBSTEP     1  COMPLETED.    CUM ITER =    180
       *** TIME =   1.80000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.29       OSCILLATION LIMIT = 0.1829
       *** WARNING ***                         CP =      84.922   TIME= 14:15:23
       *DIM command.
       *** WARNING ***                         CP =      84.969   TIME= 14:15:23
       Material number 2 (used by element 19193) should normally have at least
       one MP or one TB type command associated with it.  Output of energy by
       material may not be available.
       01055371  VERSION=WINDOWS x64   14:15:23  JAN 26, 2023 CP=     85.031
       *** LOAD STEP   181   SUBSTEP     1  COMPLETED.    CUM ITER =    181
       *** TIME =   1.81000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      85.375   TIME= 14:15:23
       *DIM command.
       *** WARNING ***                         CP =      85.453   TIME= 14:15:23
       01055371  VERSION=WINDOWS x64   14:15:23  JAN 26, 2023 CP=     85.516
       *** LOAD STEP   182   SUBSTEP     1  COMPLETED.    CUM ITER =    182
       *** TIME =   1.82000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      85.844   TIME= 14:15:23
       *DIM command.
       *** WARNING ***                         CP =      85.906   TIME= 14:15:24
       01055371  VERSION=WINDOWS x64   14:15:24  JAN 26, 2023 CP=     85.969
       *** LOAD STEP   183   SUBSTEP     1  COMPLETED.    CUM ITER =    183
       *** TIME =   1.83000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      86.297   TIME= 14:15:24
       *DIM command.
       *** WARNING ***                         CP =      86.344   TIME= 14:15:24
       01055371  VERSION=WINDOWS x64   14:15:24  JAN 26, 2023 CP=     86.422
       *** LOAD STEP   184   SUBSTEP     1  COMPLETED.    CUM ITER =    184
       *** TIME =   1.84000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      86.750   TIME= 14:15:24
       *DIM command.
       *** WARNING ***                         CP =      86.828   TIME= 14:15:24
       01055371  VERSION=WINDOWS x64   14:15:25  JAN 26, 2023 CP=     86.891
       *** LOAD STEP   185   SUBSTEP     1  COMPLETED.    CUM ITER =    185
       *** TIME =   1.85000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      87.203   TIME= 14:15:25
       *DIM command.
       *** WARNING ***                         CP =      87.281   TIME= 14:15:25
       01055371  VERSION=WINDOWS x64   14:15:25  JAN 26, 2023 CP=     87.391
       SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr
       *** LOAD STEP   186   SUBSTEP     1  COMPLETED.    CUM ITER =    186
       *** TIME =   1.86000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      87.719   TIME= 14:15:25
       *DIM command.
       *** WARNING ***                         CP =      87.797   TIME= 14:15:25
       01055371  VERSION=WINDOWS x64   14:15:25  JAN 26, 2023 CP=     87.859
       *** LOAD STEP   187   SUBSTEP     1  COMPLETED.    CUM ITER =    187
       *** TIME =   1.87000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.04       OSCILLATION LIMIT = 0.1804
       *** WARNING ***                         CP =      88.203   TIME= 14:15:26
       *DIM command.
       *** WARNING ***                         CP =      88.266   TIME= 14:15:26
       01055371  VERSION=WINDOWS x64   14:15:26  JAN 26, 2023 CP=     88.344
       *** LOAD STEP   188   SUBSTEP     1  COMPLETED.    CUM ITER =    188
       *** TIME =   1.88000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  17.95       OSCILLATION LIMIT = 0.1795
       *** WARNING ***                         CP =      88.656   TIME= 14:15:26
       *DIM command.
       *** WARNING ***                         CP =      88.750   TIME= 14:15:26
       01055371  VERSION=WINDOWS x64   14:15:26  JAN 26, 2023 CP=     88.812
       *** LOAD STEP   189   SUBSTEP     1  COMPLETED.    CUM ITER =    189
       *** TIME =   1.89000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  17.90       OSCILLATION LIMIT = 0.1790
       *** WARNING ***                         CP =      89.141   TIME= 14:15:27
       *DIM command.
       *** WARNING ***                         CP =      89.172   TIME= 14:15:27
       01055371  VERSION=WINDOWS x64   14:15:27  JAN 26, 2023 CP=     89.250
       *** LOAD STEP   190   SUBSTEP     1  COMPLETED.    CUM ITER =    190
       *** TIME =   1.90000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      89.578   TIME= 14:15:27
       *DIM command.
       *** WARNING ***                         CP =      89.625   TIME= 14:15:27
       01055371  VERSION=WINDOWS x64   14:15:27  JAN 26, 2023 CP=     89.688
       *** LOAD STEP   191   SUBSTEP     1  COMPLETED.    CUM ITER =    191
       *** TIME =   1.91000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  18.03       OSCILLATION LIMIT = 0.1803
       *** WARNING ***                         CP =      90.016   TIME= 14:15:28
       *DIM command.
       *** WARNING ***                         CP =      90.109   TIME= 14:15:28
       01055371  VERSION=WINDOWS x64   14:15:28  JAN 26, 2023 CP=     90.172
       *** LOAD STEP   192   SUBSTEP     1  COMPLETED.    CUM ITER =    192
       *** TIME =   1.92000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      90.516   TIME= 14:15:28
       *DIM command.
       *** WARNING ***                         CP =      90.562   TIME= 14:15:28
       01055371  VERSION=WINDOWS x64   14:15:28  JAN 26, 2023 CP=     90.625
       *** LOAD STEP   193   SUBSTEP     1  COMPLETED.    CUM ITER =    193
       *** TIME =   1.93000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      90.938   TIME= 14:15:29
       *DIM command.
       *** WARNING ***                         CP =      91.016   TIME= 14:15:29
       01055371  VERSION=WINDOWS x64   14:15:29  JAN 26, 2023 CP=     91.094
       *** LOAD STEP   194   SUBSTEP     1  COMPLETED.    CUM ITER =    194
       *** TIME =   1.94000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      91.422   TIME= 14:15:29
       Parameter VARY_LD already exists.  It is deleted and redefined by the
       *DIM command.
       *** WARNING ***                         CP =      91.484   TIME= 14:15:29
       01055371  VERSION=WINDOWS x64   14:15:29  JAN 26, 2023 CP=     91.562
       *** LOAD STEP   195   SUBSTEP     1  COMPLETED.    CUM ITER =    195
       *** TIME =   1.95000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      91.891   TIME= 14:15:29
       *DIM command.
       *** WARNING ***                         CP =      92.000   TIME= 14:15:30
       01055371  VERSION=WINDOWS x64   14:15:30  JAN 26, 2023 CP=     92.062
       *** LOAD STEP   196   SUBSTEP     1  COMPLETED.    CUM ITER =    196
       *** TIME =   1.96000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      92.391   TIME= 14:15:30
       *DIM command.
       *** WARNING ***                         CP =      92.484   TIME= 14:15:30
       01055371  VERSION=WINDOWS x64   14:15:30  JAN 26, 2023 CP=     92.547
       *** LOAD STEP   197   SUBSTEP     1  COMPLETED.    CUM ITER =    197
       *** TIME =   1.97000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      92.891   TIME= 14:15:30
       *DIM command.
       *** WARNING ***                         CP =      92.922   TIME= 14:15:30
       01055371  VERSION=WINDOWS x64   14:15:30  JAN 26, 2023 CP=     93.000
       *** LOAD STEP   198   SUBSTEP     1  COMPLETED.    CUM ITER =    198
       *** TIME =   1.98000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      93.328   TIME= 14:15:31
       *DIM command.
       *** WARNING ***                         CP =      93.391   TIME= 14:15:31
       01055371  VERSION=WINDOWS x64   14:15:31  JAN 26, 2023 CP=     93.453
       *** LOAD STEP   199   SUBSTEP     1  COMPLETED.    CUM ITER =    199
       *** TIME =   1.99000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      93.797   TIME= 14:15:31
       *DIM command.
       *** WARNING ***                         CP =      93.828   TIME= 14:15:31
       01055371  VERSION=WINDOWS x64   14:15:31  JAN 26, 2023 CP=     93.891
       *** LOAD STEP   200   SUBSTEP     1  COMPLETED.    CUM ITER =    200
       *** TIME =   2.00000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      94.234   TIME= 14:15:32
       *DIM command.
       *** WARNING ***                         CP =      94.266   TIME= 14:15:32
       01055371  VERSION=WINDOWS x64   14:15:32  JAN 26, 2023 CP=     94.344
       *** LOAD STEP   201   SUBSTEP     1  COMPLETED.    CUM ITER =    201
       *** TIME =   2.01000         TIME INC =  0.100000E-01  NEW TRIANG MATRIX
       *** WARNING ***                         CP =      94.672   TIME= 14:15:32
       *DIM command.
       SET PARAMETER DIMENSIONS ON  VARY_LD TYPE=ARRA  DIMENSIONS= 24107     1     1
       *DIM command.
       SELECT       FOR ITEM=TYPE COMPONENT=
        IN RANGE         3 TO          3 STEP          1
             2204  ELEMENTS (OF      21396  DEFINED) SELECTED BY  ESEL  COMMAND.
       SELECT      ALL NODES HAVING ANY ELEMENT IN ELEMENT SET.
             4549 NODES (OF      24107  DEFINED) SELECTED FROM
           2204 SELECTED ELEMENTS BY NSLE COMMAND.
       DELETE SPECIFIED SURFACE LOAD HFLU FOR ALL SELECTED ELEMENTS- ALL LKEY
       NUMBER OF HFLU SURFACE LOADS DELETED=    2204
       SELECT ALL ENTITIES OF TYPE= ALL  AND BELOW
        END OF MOVING HEAT FLUX
       USE AUTOMATIC TIME STEPPING THIS LOAD STEP
       USE      20 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL  DEGREES OF FREEDOM
       FOR AUTOMATIC TIME STEPPING:
         USE 100000000 SUBSTEPS AS A MAXIMUM
         USE     20 SUBSTEPS AS A MINIMUM
       INCLUDE TRANSIENT EFFECTS FOR  ALL DEGREES OF FREEDOM THIS LOAD STEP
       TIME=  4.0000
       *********** Moving Heat Flux: Moving Heat Flux 2 ***********
       FINISH SOLUTION PROCESSING
       ***** ROUTINE COMPLETED *****  CP =        97.969
       01055371  VERSION=WINDOWS x64   14:15:36  JAN 26, 2023 CP=     97.969
                ***** MAPDL ANALYSIS DEFINITION (PREP7) *****
       CMBLOCK read of NODE component FACE1     completed
       CMBLOCK read of NODE component PATH1     completed
       CMBLOCK read of NODE component START1    completed
       You have already entered the general preprocessor (PREP7).
       PARAMETER INX =     1.000000000
       PARAMETER LSTP =     200.0000000
       *** ERROR ***                           CP =      97.969   TIME= 14:15:36
       Parameter LSTP needs subscripts.
       NUMBER OF WARNING MESSAGES ENCOUNTERED=        408
       NUMBER OF ERROR   MESSAGES ENCOUNTERED=          1
      +--------------------- M A P D L   S T A T I S T I C S ------------------------+
      Release: 2023 R1            Build: 23.1       Update: UP20221128   Platform: WINDOWS x64
      Date Run: 01/26/2023   Time: 14:15     Process ID: 6224
      Operating System: Windows 10  (Build: 19044)
      Processor Model: 12th Gen Intel(R) Core(TM) i7-12700H
      Compiler: Intel(R) Fortran Compiler Version 19.0.5  (Build: 20190815)
                Intel(R) C/C++ Compiler Version 19.0.5  (Build: 20190815)
                Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191125
                BLAS Library supplied by Intel(R) MKL
      Number of machines requested            :    1
      Total number of cores available         :   20
      Number of physical cores available      :   14
      Number of processes requested           :    4
      Number of threads per process requested :    1
      Total number of cores requested         :    4 (Distributed Memory Parallel)
      MPI Type: INTELMPI
      MPI Version: Intel(R) MPI Library 2021.5 for Windows* OS
      GPU Acceleration: Not Requested
      Job Name: file0
      Input File: dummy.dat
        Core                Machine Name   Working Directory
           0             DESKTOP-KV8LMEO   C:\Users\candt\AppData\Local\Temp\WB_candt_12860_2\_ProjectScratch\ScrE60B
           1             DESKTOP-KV8LMEO   C:\Users\candt\AppData\Local\Temp\WB_candt_12860_2\_ProjectScratch\ScrE60B
           2             DESKTOP-KV8LMEO   C:\Users\candt\AppData\Local\Temp\WB_candt_12860_2\_ProjectScratch\ScrE60B
           3             DESKTOP-KV8LMEO   C:\Users\candt\AppData\Local\Temp\WB_candt_12860_2\_ProjectScratch\ScrE60B
      Latency time from master to core     1 =    2.015 microseconds
      Latency time from master to core     2 =    3.645 microseconds
      Latency time from master to core     3 =    3.607 microseconds
      Communication speed from master to core     1 = 12660.23 MB/sec
      Communication speed from master to core     2 = 10193.81 MB/sec
      Communication speed from master to core     3 =  7956.56 MB/sec
      Total CPU time for main thread                    :       94.4 seconds
      Total CPU time summed for all threads             :       98.0 seconds
      Elapsed time spent obtaining a license            :        0.5 seconds
      Elapsed time spent pre-processing model (/PREP7)  :        0.1 seconds
      Elapsed time spent solution - preprocessing       :       18.2 seconds
      Elapsed time spent computing solution             :       64.1 seconds
      Elapsed time spent solution - postprocessing      :        3.5 seconds
      Elapsed time spent post-processing model (/POST1) :        0.0 seconds
      Equation solver used                              :            Sparse (symmetric)
      Equation solver computational rate                :       18.3 Gflops
      Sum of memory used on all processes               :      768.0 MB
      Sum of memory allocated on all processes          :     5184.0 MB
      Physical memory available                         :         16 GB
      Total amount of I/O written to disk               :        1.8 GB
      Total amount of I/O read from disk                :        1.0 GB
      +------------------ E N D   M A P D L   S T A T I S T I C S -------------------+
       |                               RUN COMPLETED                                 |
       |  Ansys MAPDL 2023 R1         Build 23.1         UP20221128    WINDOWS x64   |
       |  Database Requested(-db)     1024 MB     Scratch Memory Requested   1024 MB |
       |  Max Database Used(Master)     63 MB     Max Scratch Used(Master)    183 MB |
       |  Max Database Used(Workers)     1 MB     Max Scratch Used(Workers)   173 MB |
       |  Sum Database Used(All)        66 MB     Sum Scratch Used(All)       702 MB |
       |        CP Time      (sec) =         97.984       Time  =  14:15:36          |
       |        Elapsed Time (sec) =         98.000       Date  =  01/26/2023        |
       All
    • Bill Bulat
      I can see from your solver output that you are using the moving heat ACT that can be downloaded from our customer portal:
      Ansys Store Moving Heat SourceV4.1 created by Ansys Inc
      It appears development of the ACT was discontinued (a note in the image above reads "Supports ANSYS: 17.0, 17.1 and 17,2") so there may be problems (some minor incompatibilities) when it is used at 2023R1. By the way, as a favor to us, when you have a question about usage of features that are not natively supported in the Mechanical GUI, it would be very helpful to us if you could tell us so. Doing so saves us a lot of time. Well, maybe you weren't even aware that this feature is essentially an add-on - if so, that's certainly not your fault.
      Anyway, when you download the moving heat ACT you get a document describing what it does and how to use it. In this document, I found the answer to your question about the spatial distribution of the moving heat source:
      Without investigating with a model of my own making, I can't say why the heat load appears to be moving on only one direction or what workaround there might be for making it double back on itself as you seem to want it to do.
      I noticed however that the output file reports a problem calling an array:
      This is likely related to the ACT not behaving as you want it to. If you haven't reviewed the documentation that comes with the moving heat ACT, it would be a good idea to download it and see if it gives you any indication that something in your setup is inconsistent with the way the ACT is supposed to be used.
      Kind regards,
      Bill
