Discovery Import
Discovery Import
Transient Thermal -> Static Structural Question
    • n222
      I have a transient thermal solution that I would to import into a static structural model so that I can get the deformation at each timestep of my transient thermal solution. I copy the temperature solution timesteps from the transient thermal solution into the static structural analysis and the static structural imported body temperature. However, when this is solved the solution is 0 deformation, so it does not seem like anything is being imported from the transient thermal solution. Is there something I am doing wrong?
    • Charudatta Bandgar
      Hello n2 ,
      I am looking into your query and will get back to you as soon as possible.
      Regards.
      Hello  n2 ,
      Can you please tell me which Discovery product you are using? Can you please share the archived file through the secure transfer link, if I mail it to you?
      Regards.
