Transient Thermal -> Static Structural Question
    • n222
      I have a transient thermal solution that I would to import into a static structural model so that I can get the deformation at each timestep of my transient thermal solution. I copy the temperature solution timesteps from the transient thermal solution into the static structural analysis and the static structural imported body temperature. However, when this is solved the solution is 0 deformation, so it does not seem like anything is being imported from the transient thermal solution. Is there something I am doing wrong?
    • Wenlong
      This question is the same as the other question you posted https://studentcommunity.ansys.com/thread/transient-thermal-static-structural-question-1/. Please refrain from posting the same questions.
      Wenlong
