July 3, 2018 at 10:13 pm
José Mantovani
SubscriberHello everyone!
I'm setting up my 2D simulation process for aerodynamic profile, and thinking about the turbulence model I came across a question. The conditions are as follows:
U = 12 m / s
c (chord length) = 0.575 m
operating at Standard air 20 ° C
And calculating the Reynolds number for this flow, Re = 470000.
So I decided to use SA turbulence model, k-epsilon Realizable and SST k-omega.
According to the literature, for external flows, around a Reynolds number of 500000 we have a turbulent flow.
So, it gave me a doubt, which would be more correct: to use these models in which I quoted or some model of transition?
Thanks for opportunity!
Mantovani.
July 4, 2018 at 7:21 am
DrAmine
Ansys EmployeeHi,
I recommend carry out a sensitivity analysis an compare the results to a transition model. You can start by using the intermittency transition model (3-Eqn model)
A.
- The topic ‘Transition or Turbulence Model?’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
