September 3, 2019 at 6:44 am
Jerry190607
SubscriberHello everyone,
I am using CFX to simulate fluid flow through a porous medium and the porous medium is moving in its orientation direction. Is there anybody knows how to set this motion for the porous domain? I found that only rotation motion option is available in the domain setting. Thanks a lot!
Cheers,
Jerry
September 3, 2019 at 7:21 am
DrAmine
Ansys EmployeeYeah only that is available as this will results in inertial forces. Translational motions would not lead to additional forces which need to be taken int account in order to use 2nd Law of Newton. So for translational
For "real" mesh motion you can use Regions of Mesh Motion.
September 3, 2019 at 9:55 am
Jerry190607
SubscriberHello Amine,
Thanks for your prompt response.
I want the inlet to keep a relative velocity to the porous medium. Is that possible to realize by using Regions of Mesh Motion?
Best regards,
Jerry
September 3, 2019 at 10:43 am
DrAmine
Ansys EmployeeMesh Motion is completely different than just accommodating the frame of reference. With Mesh Motion you are moving the mesh and not just moving the frame of reference.
September 14, 2019 at 6:07 am
Jerry190607
It is a good idea to use Regions of Mesh Motion. But the problem is that Regions of Mesh Motion is not available in porous domain. Is there any way to move porous domain with Regions of Mesh Motion? Thanks!
Best Regards,
Jerry
2706
2146
1357
1144
462
