Photonics
Photonics
Transmission and cross coupling coefficient (tau and kappa) Lumerical MODE
    • Catherine.antipuesto
      Good day!
      I would just like to ask how I can obtain the tranmission and cross coupling coeffecient of a microring resonator using Lumerical Script in Microring resonator. Furthermore, these coeffecients vary in wavelengths. How can I get this plot?
      Thank you!
    • jackzhf
      https://optics.ansys.com/hc/en-us/articles/360042800293
      This page contains a package of LSF codes and MODE and FDTD project files that you can use to extract tau and kappa in terms of wavelength. Hope that it will help. Good day.
    • Guilin Sun
      @jackzhf thank you for help!
      Please  note that, kappa and tao are complex numbers so in the FDTD simulation, it could change their phases depending on the port locations. The power coupling coefficient can be simulated without ambiguity, such as the online example.
      Hello Thank you for your replies. I have read the article that you mentioned however, I was not able to find exactly, how I can graph the coeffecients kappa and tau. Can I please ask for your guidance? Thank you!
    • jackzhf
      Did you try the files and check the codes in the LSF files on the page?
      https://optics.ansys.com/hc/article_attachments/360057321293/gs_ring_labels.png
      Tips: keep an eye of t11 and t12
      Associated files
      fdtd_results.ldf
      ring_resonator.lms
      ring_resonator_fdtd.lsf
      https://optics.ansys.com/hc/en-us/article_attachments/360056406794/ring_resonator_fdtd.lsf
      ring_resonator.fsp
      ring_resonator.lsf
      https://optics.ansys.com/hc/en-us/article_attachments/360057295953/ring_resonator.lsf
      plot - Script command
      https://optics.ansys.com/hc/en-us/articles/360034410474-plot-Script-command
      Yes I already checked it but the calculation of tau is only theoretical and depends only on the Q and FSR values typed in the script. I was wondering if there is a way to get the tau of the designed microring resonator in Lumerical Mode by using obtaining the data from the monitors.
      Thank you!
      • jackzhf
        Step 1 in the following example should fit your purpose using FDTD solver and hope it will help.
        https://optics.ansys.com/hc/en-us/articles/360042322794-Ring-Modulator
Viewing 5 reply threads
