April 3, 2022 at 10:25 pm
yisu0279
SubscriberIn the simulation, I used the dipole sources with simulation time 5000fs . Thus I used this code to do the normalize: Px1 = transmission("x1")*sourcepower(f)/dipolepower(f);
Before normalized, my left transmission looks like this:
April 4, 2022 at 8:05 pmGuilin Sun
Ansys EmployeeSince I do not know what device is this and what are the settings, I can only guess the cause. It might be due to not long enough simulation or not small enough autoshutoff min.
Please visit this post: Simulation time and frequency domain monitors
If you can read in Chinese, please also refer this post:
Ansys Insight: 透射率反射率大于1,或者透射率反射率之和大于1的原因与解决方案--综合贴Viewing 1 reply thread- You must be logged in to reply to this topic.
- Error on Lumerical device
2630
2104
1327
1110
461
