February 23, 2023 at 10:10 am
amir.mb1377
SubscriberHello. How i should considering 3 series elements for mat-197 in ls dyna software??
February 23, 2023 at 4:30 pm
Andreas Koutras
Ansys EmployeeHere are some sample keywords that may help.
$ MAT (Material) cards
*MAT_SEISMIC_ISOLATOR
$ sliding isolator
1 2000.0 0.0 0.0 0.0 0.005 1.e8 0
1.0e5
0.2 0.10 0.5 0.150
$ elastomeric isolator
2 2000.0 0.0 0.0 0.0 0.005 1.e8 1
1.0e5
0.0 0.0 0.0 0.0 0.0 0.0
30.e3 0.05 0.150
$ sliding isolator with radii
10 2000.0 0.0 0.0 0.0 0.005 1.e8 2
-1.0e5
0.2 0.10 0.5 0.5 0.5 0.50 1.e5
0.1 0.40 0.30
$ SECTION cards
*SECTION_BEAM
1 6 0.0 0.0 0.0 0.0
$ vol iner cid ca offset rrcon srcon trcon
0.125 10.0 0 0.0 0.0 0.0 0.0 0.0
2 6 0.0 0.0 0.0 0.0
$ PART cards
*PART
sliding isolator
1 1 10 0 0 0 0 0
*PART
sliding isolator
2 2 2 0 0 0 0 0
*PART
10 1 10 0 0 0 0 0
$ NODE cards
*NODE
1 0.0 0.0 0.0 0 0
2 0.0 0.0 0.0 0 0
3 0.24974091 0.0 0.0 0 0
4 0.24974091 0.0 0.0 0 0
13 0.5 0.0 0.0 0 0
14 0.5 0.0 0.0 0 0
$ ELEMENT cards
*ELEMENT_BEAM
1 1 1 2 0
2 2 3 4 0
10 10 13 14 0
$ BOUNDARY cards
*BOUNDARY_PRESCRIBED_MOTION_NODE
2 1 0 1 2.0 0 0.0 0.0
$ 2 2 0 2 2.0 0 0.0 0.0
4 1 0 1 2.0 0 0.0 0.0
$ 4 2 0 2 2.0 0 0.0 0.0
$ 14 1 0 1 2.0 0 0.0 0.0
14 2 0 1 2.0 0 0.0 0.0
*BOUNDARY_SPC_NODE
1 0 1 1 1 0 0 0
3 0 1 1 1 0 0 0
13 0 1 1 1 0 0 0 -
February 24, 2023 at 2:49 pm
amir.mb1377
SubscriberHello. You don't have the image of the isolator modeled in ls dyna. And that you don't have the file of these samples that you sent? -
February 24, 2023 at 7:55 pm
February 24, 2023 at 8:16 pm
amir.mb1377
SubscriberHello. The model consists of 3 beam elements with zero length. What does the distance between 3 and the element depend on? Should the mesh be added to the elements?
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3744
2573
1809
1236
594
