December 28, 2022 at 6:19 pm
amir.mb1377
SubscriberHello
In material 197, in ls dyna software, the shape of isolator should be drawn in 3D or 2D? The type of isolator element should be beam, but it is not clear whether it should be drawn in three dimensions or two dimensions?
December 29, 2022 at 6:34 pm
Reno Genest
Ansys EmployeeHello Amir,
*SECTION_BEAM elform=6 (discrete beam/cable) should be in 3D.
Let me know how it goes.
Reno.
December 29, 2022 at 6:47 pm
Jim Day
Ansys EmployeeJust as with any other beam element, it will appear as a 1D, 2-noded element. It is possible, though not mandatory, for the two nodes to be coincident since it's a "discrete" beam element (beam formulation 6). To view the local r,s,t coordinate system for the element, read the keyword input file into LS-PrePost and select EleTol>Ident>Element>Beam>Elem Dir . If you see only the r-axis, then modify the keyword input to add a third node N3 in *ELEMENT_BEAM, which will serve to orient the s- and t-axes. For beam formulation 6, the ASCII output file disbout may be useful. To write this output file, include the keyword *DATABASE_DISBOUT in your keyword input file and specify the desired output interval in time units. -
December 29, 2022 at 8:04 pm
amir.mb1377
SubscriberHello Reno
thanks a lot
You don't have a sample project from mat 197. I searched the site, but I could not find an example related to the isolator, which is the same material as mat197?
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2524
2066
1279
1096
457
