November 30, 2022 at 4:06 pm
amir.mb1377
SubscriberHello
In mat-197, the type of element must be beam? Do you have an example that uses mat-197?
November 30, 2022 at 6:42 pm
Andreas Koutras
Ansys EmployeeHello,
MAT_197 has been developed for discrete beam elements, meaning for ELFORM=6 on *SECTION_BEAM.
Looking at the corresponding references mentioned in the manual vol II for MAT_197 may help.
December 1, 2022 at 12:20 pm
amir.mb1377
SubscriberHello
Should the drawn section be in the form of a beam?? Is it two-dimensional?
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2564
2078
1291
1106
459
