October 23, 2023 at 9:19 pm
Wojciech Bissinger
SubscriberHello everyone,
I am currently working on a project where I am going to do a static analysis of a rib structure using pressure load data obtained from a CFD simulation of the wing in ANSYS Fluent.
However, I have encountered an issue during the analysis. The pressure values on the rib remain unchanged compared to those on the wing. It seems like the program didn't account that the surface area reduced along the Z-axis. I anticipated that the pressure on the rib should proportionally increase due to the reduced surface area.
I'm wondering if ANSYS Fluent has a specific feature or method to handle this kind of analysis and help me achieve the desired results. I'd greatly appreciate any guidance, advice, or insights on how to properly set up and execute this type of static analysis within ANSYS Fluent.
Thank you in advance for your assistance!
October 25, 2023 at 9:10 am
Forum ModeratorIf you post some images of the Fluent results we may be able to spot something.
October 25, 2023 at 3:49 pm
October 25, 2023 at 4:00 pm
Forum ModeratorHave you done a mesh sensitivity study? Have you checked the model, materials, and convergence? If so that may be the correct answer. What does theory/experience tell you?
October 25, 2023 at 4:11 pm
Wojciech Bissinger
SubscriberEverything seems to be good. I checked the mesh by comparing cl results for different angles of attack with real empirical research conducted on the Selig 1223 airfoil profile
October 25, 2023 at 8:45 pm
Wojciech Bissinger
SubscriberI'm wondering if it's possible to modify the results of a CFD simulation to make the imported pressure load increase proportionally as the surface area decreases
October 26, 2023 at 8:20 am
Forum ModeratorYou mean scale the force? I'm not sure what you can read in Mechanical, but you could export xy data (pressure with x or y position) from Fluent and mess with that.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
