September 20, 2021 at 4:25 am
Vivjk94
SubscriberHello, i am trying to perform a 2D gear pump simulation as part of my project. I have modelled a gear pump where the gear has 13 teeth and rotating at 2000 rpm. I have used water as the fluid and used a fine mesh with triangular elements. The pump inlet boundary condition has 0 Pascal and outlet has 2000 psi pressure. the udf code used is as follows:
Rotating motion for gear 1
#include "udf.h"
DEFINE_CG_MOTION(gear_1_new,dt,vel,omega,time,dtime)
real t = CURRENT_TIME;
NV_S (vel, = , 0.0);
NV_S (omega, = , 0.0);
omega[2] = -209.4395;
Rotating motion for gear 2
#include "udf.h"
DEFINE_CG_MOTION(gear_2_new,dt,vel,omega,time,dtime)
omega[2] = 209.4395;
The dynamic mesh settings are as follows:
September 20, 2021 at 9:38 amRob
Ansys EmployeeChances are the gap between the teeth gets to be small and that's then skewing the mesh. There's been a lot of work on gears through the last couple of releases to resolve that problem and also the speed where we're spraying liquid around the gearbox. I don't have anything from our (technical) side to share, but check the Ansys blog posts as I think there was something published there.
September 20, 2021 at 2:22 pmVivjk94
SubscriberThat figures. i had left almost 0 gap between the two gears. I will try with more gap.
Thank you Vivek
September 22, 2021 at 5:28 pmVivjk94
Subscriberupdate- i gave about 1mm gap between the two gears and the simulation ran for a couple of timesteps which would never happened before in my old setup. I also find that reducing time step allows the simulation to run for a lot more time steps.
Thank you Rob.
March 2, 2022 at 7:17 pmyeico01
SubscriberI have the same problem, could you tell me how you solved it?
Viewing 4 reply threads- You must be logged in to reply to this topic.
2508
2064
1279
1088
456
