October 22, 2018 at 7:49 pm
sameerfares
SubscriberHi All,
I am not sure why my geometry doesnt open in ANSYS mechanical.
Sam
October 22, 2018 at 8:10 pm
Sandeep Medikonda
Ansys EmployeeWhat are the errors you are seeing? Have you been able to open your part in SpaceClaim/Design Modeler?
Did you right click in WB and try updating the Model Cell, before you open Mechanical?
Sandeep -
October 22, 2018 at 8:17 pm
October 22, 2018 at 8:20 pm
sameerfares
SubscriberSandeep,
i checked the geomtery with "Check Geometry" and it said its ok.
Sam
October 22, 2018 at 8:30 pm
SubscriberANSYS experts,
SpaceClaim opens and I can see the geometry. I saved a SpaceClaim document, created a new Workbench file with a new Static Structural and Imported that SpaceClaim file into the Geometry cell. When I Refreshed the system I got errors:
- System.Exception: Unable to attach to geometry file E:ansysdatastudentcommunitySam.FaresLapped geometry 1.02.scdoc. Unable to attach geometry.
- at Ansys.Simulation.Core.Commands.RefreshModel.ExecuteCommand(IFullContext context)
- at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute(IFullContext context)
- at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
- at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
- at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
- --- Ansys.Core.Commands.CommandFailedException: Unable to attach to geometry file E:ansysdatastudentcommunitySam.FaresLapped geometry 1.02.scdoc. Unable to attach geometry.
- CommandName: Mechanical.RefreshModel(Container="Model", RemainingContainers=["Setup", "Solution", "Results"])
- at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException(Exception e)
- at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
- at Ansys.ProjectSchematic.Commands.RefreshCommand.RefreshComponents(IFullContext context, IEnumerable`1 componentsToRefresh, Boolean refreshUnfulfilled)
- CommandName: Refresh()
- at Ansys.ProjectSchematic.Commands.RefreshCommand.InvokeAndWait(IProtectedContext context, IProgressMonitor progressMonitor)
- at Ansys.ProjectSchematic.GuiOperations.RefreshProjectGui.Invoke(GuiOperationContext context)
- at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMetaData operationData)
- at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction, Boolean deferredRefreshOnly)
I went back to SpaceClaim and used the Repair tab to check for various defects. Only Split Edges showed something, which I repaired, but that did not help the geometry to transfer to Mechanical.
Sam,
Open SpaceClaim, Save As STEP file. Open a new Static Structural analysis and Import the STEP file into the Geometry Cell. That successfully Attached to the Model cell.
You can also open the Geometry in SpaceClaim.
Peter -
October 23, 2018 at 1:47 pm
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2064
1279
1096
456
