Discovery Import
Discovery Import
try to install 2021 R2 license error
    • sai
      Need help to install both SC and Discovery Thanks Sai Chiang
    • Devendra Badgujar
      Hi sai I checked your account and it looks like you have a Subscription ( Named User ) license. So you don't need to run the license manager as your license will be verified online upon login. Please follow the instructions mentioned below to switch the licensing mode to Subscription to confirm if it is set correctly. Go to Windows Start menu, ANSYS 2021 R2 folder and open "Discovery Licensing Mode Manager". In this panel, select the appropriate license mode viz Subscription for your case (refer below snapshot), then click Save and Exit. After that is done, please launch Discovery, when a login is prompted please login with your details for license verification. Let me know if you need further assistance. Regards.
