November 5, 2020 at 8:42 pm
carlosjponte
SubscriberDear Sirs, I'm trying to erase a solid section using a complex boundary, but I still can't figure how to do it. Explaining a little bit more, I'm performing an API 579 part 4 lvl3 evaluation. I have the shell of a heat exchanger (see IMAGE 1) that internally has loosen thickness due to corrosion. Using UT data, I've performed the full thickness profile for the corroded area and I have already the full corroded surface as you can see in the IMAGE 2. This surface is placed inside the volume of the shell. Now the question is: how do I remove the corroded volume?. I tried the pull function with cutting the material up to the inner diameter of the shell but it doesn't work for multiple surfaces. Any help will be appreciated for this. Thank you, Carlos
November 5, 2020 at 8:47 pm
November 27, 2020 at 6:31 am
Charudatta Bandgar
SubscriberHello Carlosponte ,
Sorry for delayed response. Is your issue sorted?
Regards.
- Can’t see license on online account
- loss of user settings
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
3744
2573
1793
1236
594
