October 25, 2018 at 6:34 pm
yank4
SubscriberHi,
When I send the TE mode wave(in -x direction) using floquet port from bottom of the box and show in overlay, it shows like this ( it is just a empty air box with and pec to block the signal propagation):
Now I want to get the value of those E field. Therefore, I set the far field(with phi = 0, theta from -180 to 180).
When I got the plot, I got like this.
The graph show the E field at 15000GHz, 20000GHz and 25000GHz using infinite sphere(phi = 0 all the time)
Could someone explain why I got this E-field graph? In my understanding, infinite sphere at theta = 0 is at top of the z aixs. And field overlay shows all the waves are blocked by the pec at the top of the z axis. However, I can not understand why I still got value at the graph. Especially at theta at 0, which clearly indicates the top part of z axis, I got E field value at 687mV at 25000GHz.
Thanks!
yank4
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
457
